  • Announcements
Sign in to follow this
Followers 0
Brazil2010
Maytag MVWX600XW0 Bravos EcoConserve won't drain/spin
1 post in this topic
Hello,
I need some help with my Maytag Bravos EcoConserve washer(Model MVWX600XW0). I hope the one of the appliantology samurais will know what the problem.
About 2mths ago, it started having a problem where it won't drain or complete the wash cycle. It wasn't doing it each time but every now and then we would find a load soaking wet when we thought it was done. But about a week ago, it stopped working properly each time we tried.
Yesterday, I ran a load and waited nearby and watched the cycles and timing. Here's what I've noticed.
-I started ‘wrinkle control’ cycle
-washer started sensing and showed 46mins in the display
-At 43mins, I could hear water being added
-At 39mins I could hear motor spinning/washing
-At 37mins, the soak cycle started
-At 36mins wash cycle started
-At 27mins noticed wash stopped (no more noise)
-Then the display changes the mins from 27 to 10mins very quickly.
-Then there is no cycle light selected (no sensing, soak, wash, rinse, spin or done) but the time remaining keeps cycling between 10, 9,8,7,..1, then 10 again and keep repeating the previous sequence.
I have read a few articles on lameanswer.com and found an article similar to my issue. Unfortunately the poster didn't comment on his topic what the solution was. It could be the water pump or the control board.
Please let me know if you have any ideas.
p.s. I have used this forum before and was very happy with the help I received. Someone even posted links to the parts I needed and made my repair a breeze. Thank you once more and I hope you'll come to my rescue again.
thanks
Followers 0
