Kenmore 110.97583820 gas dryer motor replacement issue
3395654 motor gas dryer Kenmore 279787
12 replies to this topic
#1 Def Egge
Def Egge
  • 5 posts
  • Flavorite Brew:Guiness Dark 72 degrees F
Posted 25 February 2012 - 08:49 PM
Senseis & Gurus,
I am new here (although I may have participated here in a past life).
I have run into an issue with what should be a simple drop-in motor replacement in my Kenmore gas dryer (model 110.97583820).
The failed motor part is listed as 3395654 and the recommended repacement is 279787.
I checked out the wiring on the replacement motor and it looks to be exactly as on the old motor with the exception of a blue jumper wired in where the broken belt switch should be. That SHOULD BE an easy pull and reconnect.
The bigger problem is with the motor bearings' fit into the dryer's motor mount. The plastic (indicated with the back arrows of death ... what is the term for these plastic pieces?) on the new motor is different than on the old one. The old one had a smooth circular surface. The new one has several bumps and irregularities that appear to be designed to lock the bearings into the motor mount yoke.
I WAS able to make the motor fit into the mount by canting it over about 45 degrees from the orientation of the original motor mount. I'll tell you what, getting those mounting clips back on to the motor mount was no easy task because of the extra plastic.
In the new orientation, I can no longer hook up the leads to the broken belt switch.
1) Can I safely go without the broken belt indicator?
2) If not, what gauge wire should I use for the jumpers? [Here's hoping that Home Depot or Lowes will have what I need!]
3) Is this a common problem with 'updated' parts numbers?
Thanks, Senseis and Gurus, for your kind attention to the Def Egge's issue.
#2 RegUS_PatOff
  • 30,192 posts
Posted 25 February 2012 - 08:59 PM
... Kenmore 110.86583820 gas dryer motor replacement issue
... Kenmore gas dryer (model 110.97583820)..
which Dryer are we talking about ?
they each use a different Motor
#3 kdog
    RoughShod
  • 7,428 posts
Posted 25 February 2012 - 09:25 PM
Here are Links to both of the motors along with the appropriate installation video's:
#4 Def Egge
Def Egge
  • 5 posts
Posted 25 February 2012 - 09:27 PM
D'oh! I am talking about the model 110.97583820.
#5 kdog
    RoughShod
  • 7,428 posts
Posted 25 February 2012 - 09:33 PM
Edited topic title
Motor Link
#6 Def Egge
Def Egge
  • 5 posts
Posted 25 February 2012 - 09:50 PM
OK Thanks for the video links and topic editing.
I see the problem now. The motor sent was NOT model 279787 but model 279827. That why there are extra tabs and nothing that lines up along the motor mount. In addition, on closer inspection, the shaft is too long on both ends.
Back to the laundromat and another week of waiting for the proper part to arrive.
#7 kdog
    RoughShod
  • 7,428 posts
Posted 25 February 2012 - 09:52 PM
Did you order from the link posted above?
#8 RegUS_PatOff
  • 30,192 posts
Posted 25 February 2012 - 09:59 PM
... I see the problem now. The motor sent was NOT model 279787 but model 279827.
the 279827 Motor sent, is for your 110.86583820 :whistling:
279787 is for your 110.97583820
#9 Def Egge
Def Egge
  • 5 posts
Posted 25 February 2012 - 10:07 PM
No ordered elsewhere.
Upon further review, I ordered the 279827 motor when I wanted the 279787 motor instead for the 110.97583820 dryer.
I am suffering from a serious case of the dumbass this month.
#10 kdog
    RoughShod
  • 7,428 posts
Posted 25 February 2012 - 10:09 PM
#11 RegUS_PatOff
  • 30,192 posts
Posted 25 February 2012 - 10:12 PM
... I am suffering from a serious case of the dumbass this month.
been there, done that :whistling:
RepairClinic 365 day return policy
customers can return any part or any product for any reason within 365 days from the date of purchase.
This includes electrically installed, electronic, special order, and out of stock parts.
http://fixitnow.com/...-return-policy/
#12 Def Egge
Def Egge
  • 5 posts
Posted 25 February 2012 - 10:37 PM
Thanks for the laugh. I actually pulled that off on a Taiwanese-American optometrist once. The look on her face was priceless. Obviously, she did not grow up watching Bugs Bunny cartoons. ;-)
This is a great place to get help. I'll be checking back on a more regular basis!
#13 kdog
    RoughShod
  • 7,428 posts
Posted 26 February 2012 - 12:11 AM
hint: Buy your parts here ==> http://www.repairclinic.com/ Posted Image Posted Image Helps support the site ...........
