Sign in to follow this
Followers 0
mikegoodman99
frigidaire gallery dryer model fse748gfso heat / DET K?
5 posts in this topic
Model fse748gfs0 / serial xd83162405
Where the dryer lint filter thingy is there is a plastic part held in by two screws. On this there are two sensors and some tabs for insulated connectors that r not pluged in but are their. On the plastic panel by the tabs it says add det k and then omit det k. Where do the insulated wires get pouted into? And the whole reason for this was dryer needed to run at least two full cycles to dry the clothes. Pulled the dryer apart to clean and found this. Prior dryer got so hot that u couldn't even touch the top. Had it repairs and was told the thermostate was replaced. After that it seemed to never get hot enough. Found this - is it the problem or one of the problems?
this one ?
... only used for Sensor (Auto) Dry
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
So - I take it that since this is a Sensor Dry dryer - if I plug this in, it should work correctly?
Thanks for the assistance Grasshopper...
OOPS - I mean Grand Master Funk - LOL
.. if I plug this in, it should work correctly?
Only affects the Auto-Dry cycles...
without it plugged in, Dryer would turn OFF before the clothes are actually dry
wouldn't cause the over-heating you mentioned
Followers 0
