Whirlpool Cabrio washer not spinning and draining. WTW6600SW2
#1
Posted 27 February 2012 - 09:49 PM
turned the machine over and pulled the pump. The impeller was working well, nothing was stuck in the pump or the hoses connected to it.
I unclamped the hoses to the pump and blew on them to see if they were clear, they were open. Checked the power to the pump, 120 v, good.
After reassembling the pump and hoses, I started the machine in the spin/ drain position with no new water going in. It did a couple of agaitations
then went into a high speed spin. the small amount of water that was still in the tub was being pumped out.
Put a little water in by starting a new cycle, moved the dial manually to spin/drain and it worked again.
However, about two hours later, the owner called saying that she tried a regular load of clothes, and the same symptons happened as
when they called me to come out. Machine got to the spin/drain cycle and there was a buzzing noise and no spin.
Could it be the timer (control board?) I don't want to guess, they are pretty expensive. Your help is appreciated!
One other thing- the owners said that they had to pull the power cord from the wall to reset the machine, they could not do it by pressing the
power button or start button.
#2
Posted 27 February 2012 - 10:14 PM
Press and hold for 4 seconds/release for 4 seconds and repeat this sequence till all the lights come on.
Press that same button to toggle thru the 5 most recent faults.
What codes are saved there?
Edited by KurtiusInterupptus, 28 February 2012 - 02:21 AM.
- Samurai Appliance Repair Man, kdog and RussTech like this
#3
Posted 02 March 2012 - 03:01 PM
cleaned it out. Everything was working fine. Running the diagnostics (auto and manual) also corrected some problem they were having with the start and power buttons.
The error codes were F32, and F71. But I think it was the clothes and coins in the bottom causing the problem.
#4
Posted 02 March 2012 - 11:51 PM
