GE stove JSP46SP2SS surface element not staying on
6 replies to this topic
#1 jkilgore34
jkilgore34
    Sōhei
  • Chief Appliantologist
  • 121 posts
  • Flavorite Brew:Dogfish Head 120 minute IPA
Posted 27 February 2012 - 10:05 PM
Talked to a customer with stove number JSP46SP2SS says the large front right burner will stay on for awhile and then will cycle off and not come back on. Infinite switch maybe? also if I have to change the element how do I get to it on this model?
    Shōgun
  • Master Samurai Tech
  • 31,400 posts
Posted 28 February 2012 - 02:28 PM
That would be the infinite switch fo sho. Pick the correct switch for that burner here ==> http://www.repaircli...96-Switch-Parts
Service manual added to Downloads section ==> http://appliantology...service-manual/
#3 jkilgore34
jkilgore34
    Sōhei
  • 121 posts
Posted 12 March 2012 - 08:54 AM
I'm having trouble with this part. I recieved the switch from my parts distributor and went to the house to change the switch. I started transfering wires from one switch to the other to find that there was not enough blades on the new switch for all the wires to go on. There is no S2 blade on the new switch. I just wondering if there is a service bulletin out on this switch. It looked like the wire that went on the s2 was for the light that indicates a burner has been turned on. Ordered a second switch and confirmed model number of stove and the second switch showed up the same. If someone has any information that would be great.
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 12 March 2012 - 09:02 AM
what part number did you get ?
#5 jkilgore34
jkilgore34
    Sōhei
  • 121 posts
Posted 12 March 2012 - 09:07 AM
WB24T10119
#6 jkilgore34
jkilgore34
    Sōhei
  • 121 posts
Posted 12 March 2012 - 08:34 PM
Searspartsdirect.com had it mislabeled on their schematic so I got the wrong part number.
    Shōgun
  • 31,400 posts
Posted 13 March 2012 - 10:26 AM
And the Moral of the Story: Always order your parts thru the part links on this site.
And they lived happily ever after.
The End.
