Maytag MAH6700AWW washer - no high speed spin
slow spin pump 8e e8
3 replies to this topic
#1 RyGuy
RyGuy
  • 2 posts
Posted 28 February 2012 - 01:06 AM
I have a MAH6700AWW that the board went out on. I got a new board and put it in and now it seems I have other issues.
The unit will not reach high speed, clothes come out wet. The pump works fine, as I also put in a new pump and checked for clogs.
I ran all checks and they all come out OK. The error code I get is 8e or e8. My model is version 11. The board they sent me is the newer one that has ports for the mems unit. They did NOT send me a mems unit with this board. Could this be whats causing my issues?
#2 kdog
    RoughShod
  • 7,428 posts
Posted 28 February 2012 - 02:52 AM
What was the reason you replaced the board, because of the spin issue ? there is literature that states series 10-14 did not have the mems pcb, but notes that if the mems harness has the harness reversed between the control and the mems, that the machine will spin at 180 rpm maximum.
The R/C link shows the harness included with the control:
http://www.repaircli...mber=MAH6700AWW
#3 kdog
    RoughShod
  • 7,428 posts
Posted 28 February 2012 - 02:56 AM
But the mems seperate :dontknowaboutyou:
#4 RyGuy
RyGuy
  • 2 posts
Posted 28 February 2012 - 04:24 PM
I replaced the control board because of a code 2e.
Also tagged with one or more of these keywords: slow, spin, pump, 8e, e8
