GE top load Washer Control Panel With Circuit Board burnt resistor WH12X10344
6 replies to this topic
#1 rolandvz71
rolandvz71
    Kohai
  • Chief Appliantologist
  • 265 posts
  • Flavorite Brew:Sweet Sun Tea
Posted 28 February 2012 - 01:51 AM
I have this GE Washer Control Panel With Circuit Board WH12X10344.
The model number on the washer has been worn off but the part # is WH12X10344
So I ordred a used replacement and would like to try to fix the orginal panel.
The resisitor has burned up on the board. Is there any one out there that can tell me what size it is?
I have done some research and it looks to be a 4K ohm with 5% tolerance?
http://i225.photobuc...ms/IMG_0372.jpg
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 28 February 2012 - 04:35 AM
... The resisitor has burned up on the board.
:kopkrab: I don't see a burned resistor
#3 rolandvz71
rolandvz71
    Kohai
  • 265 posts
Posted 28 February 2012 - 10:14 AM
Sorry I have removed the resisitor here is where the ressitor would be soldered
http://i225.photobuc...ms/IMG_0376.jpg
Is it worth fixing or should I sell it for parts?
#4 RegUS_PatOff
  • 33,588 posts
Posted 28 February 2012 - 01:15 PM
L2 ?
L2 is not a resistor, it's a Coil and it looked good (before removal)
#5 rolandvz71
rolandvz71
    Kohai
  • 265 posts
Posted 28 February 2012 - 01:48 PM
What we have here is a failure to communicate..... 1st pic is of a good "coil" on the replacement board I bought.
The 2nd pic is of the original board I pulled from the washer the coil was buried really bad o make out.
Clear as mud? I hope I was able to lift some fog.....I was not clear in my post.
Thx for the response
#6 RegUS_PatOff
  • 33,588 posts
Posted 28 February 2012 - 01:59 PM
if that is
Yellow
Black
Red
Gold
that would be a 4000 uH Inductor (coil)
but there would be a reason why that Coil burned up.
but manufacturers don't provide schematic diagrams,
unless you can trace to where that Coil connects to . . .
#7 rolandvz71
rolandvz71
    Kohai
  • 265 posts
Posted 28 February 2012 - 02:49 PM
Sould like I might open a can of worms.....I think I will let sleeping dogs lie.....
