Hotpoint RVM1625SJ01 Microwave Oven - No Heat
no heat ? and there is heat.
3 replies to this topic
#1 ceak
ceak
  • Chief Appliantologist
  • 13 posts
  • Flavorite Brew:water
Posted 28 February 2012 - 10:21 PM
Hi, Hot Point had no Heat put a cup of water tryed it out for 1min no heat. Checked mag TCO OK, checked diode OK, Capacitor good, control board seem fine had a display clock timer fan controls lights all worked, checked the rest of the TCO's all ok. all three door switchs good. Magnetron good, did not take the microwave down off the wall. unplugged checked with meter and visually checked magnets ok. Put it all back together took a cup of water 2min and what do know 190 was it the "gookus" Thanks
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 28 February 2012 - 10:38 PM
... was it the "gookus" Thanks
:banana: :banana: :banana:
#3 ceak
ceak
  • 13 posts
Posted 28 February 2012 - 10:48 PM
The gookus, just wanted to throw that out there.:)
#4 Budget Appliance Repair
  • 4,966 posts
Posted 29 February 2012 - 07:40 AM
Bad wire connections on mag tube not letting the low 3 volts for the heating of the mag filiment to get it firing.
Quite a few years ago when I worked in a shop and worked on microwaves, I seemed to run into this alot on the GE's but also a few times in other brands also.
The fix I finally found was to actually solder the hi-voltage magtube leads so that the wire and spade connector have a solid bond, (with a solder iron heat the connector where it is crimped to the hi-voltage lead wires and flow a little solder into the crimp joint).
William Burk (Willie)
Eureka, CA 95501
