GE Profile (PDW7300G00BB) dishwasher - no water pumping
dishwasher PDW7300G00BB GE Profile
4 replies to this topic
#1 CaptQ
CaptQ
  • 3 posts
  • Flavorite Brew:Most Heife Weissen
Posted 29 February 2012 - 02:54 PM
I have a GE Profile (PDW7300G00BB) dishwasher which powers up and turns on. However water is not pumping (and impeller blades not turning).
Heater element is getting hot and if I dump water into the bottom, the washer will also pump it out.
To me, I'm guessing the electronic actuator for the water is broke. Any ideas?
I am handy and not afraid to take things apart. I have voltage meters so I can test components, I just need to know what to look for, test and how. TIA Herb
  • 24,218 posts
Posted 29 February 2012 - 05:19 PM
Are you saying water is not flowing into the basin when you start a cycle? If so, then yes, begin your investigation at the water inlet valve ==> http://www.repaircli...er=PDW7300G00BB
It's located behind the kickplate.
You can check the valve coil for continuity. A better check would be to see if it's getting 120vac when the dishwasher should be filling.
#3 CaptQ
CaptQ
  • 3 posts
Posted 11 March 2012 - 01:18 PM
OK, I finally got around to testing the Water Inlet Valve and it seems I'm reading zero voltage when the washer should be filling w/ water. I also pulled the cover off the float on the inside of the washer and when I put a piece of duct tape on ball of the float, it moves up and down and I here a slight clicking when moving the float up and down manually.
So maybe the float switch is shot, and maybe the control panel? I know very little about washer so I'm just guessing.
#4 CaptQ
CaptQ
  • 3 posts
Posted 11 March 2012 - 01:28 PM
Also, are there schematics available for this washer?
Where to I find a list of common parts which typically are replaced for a washer.
#5 RegUS_PatOff
  • 30,200 posts
Posted 11 March 2012 - 03:38 PM
check the operation of the Flood (float) Switch with an OHM meter
Check the resistance across the Water Valve.
Note the Dual Zener diodes across the Water Valve.
If it shorts, would ruin the Controller
for service manuals and other perks, become an Apprentice
from the 44 page service manual
Also tagged with one or more of these keywords: dishwasher, PDW7300G00BB, GE Profile
