Sign in to follow this
Followers 0
mrberad
Bosch Nexxt 300 - Shake rattle & roll
5 posts in this topic
OK I haven't had a problem with my Bosch washer in about 10 months, so it decided it missed you guys.
This sucker is shaking the house pretty badly nowadays - I got some $40 anti vibration pads and this is the improvement courtesy of you tube http://youtu.be/4MxCf07Wa24 this guy is coming from its top spin down. Please notice the wobble of the drum in and out.
Now I know you guys like to blame anything that is not a concrete floor for shaking, but why now after almost 3 years?
Any insight is appreciated. I wish I had my mom's 1976 avocado green Maytag right about now.
Cheers!
<<<OK I haven't had a problem with my Bosch washer in about 10 months>>>
<<<Now I know you guys like to blame anything that is not a concrete floor for shaking, but why now after almost 3 years?>>>
I'm confused here.
In any case---this washer is not a good candidate for WOOD FLOOR laundry rooms.
If the washer is on a WOOD FLOOR---it is virtually impossible to get this model to be 100% vibration-free during the spin cycle.
Try the following:
1) Level the washer with a LEVEL TOOL
2) Once level---get rid of the LEVEL TOOL---it'll never be needed again.
3) Place a single towel (to mimic an imbalanced load condition) in the tub and select the SPIN ONLY cycle.
4) As the tub begins to *ramp-up* to a faster spin speed---feel both of the front leveling legs of the washer with your fingers.
Adjust the leveling leg that is lifting/hopping off the floor (usually 1/4 to 1/2 turn)until the leg stops lifting up & down.
5) Lock all of the leveling legs of the washer (this done by tightening a *nut* on the leg---against the washer frame) to prevent an
out-of-adjustment of the leveling leg from normal vibration over time.
This applies to all front loading washers on WOOD or CONCRETE FLOORS.
NOTE:
On your YouTube video---I could not determine if the floor was congoleum or tile.
If the flooring is tile---verify that none of the leveling legs sits on the edge of the tile (grout section).
A leveling leg on the edge of a tile will cause shaking (not a flat surface)
Again---if the laundry room has a WOOD FLOOR---the best that can be done for this Bosch washer---is to reduce/minimize the degree/severity of the shaking/vibration/rattle during the spin cycle.
Academy Fellow:
Thank you for taking the time to respond to my post. The washer rests on tile with a wood subfloor of an 80 year old albeit still sturdy house.
I agree with you that this washer is not ideal for a wood floor, but it has become progressively worse in 3 short years of ownership.
So, I re leveled the washer per your instructions. I removed the anti vibration pads and adjusted all 4 leveling legs (the ones in the rear do not self level). Two of the locking nuts were loose and I took care not to place any legs near the grout.
I ran the spin cycle with one towel and adjusted and tighten the legs. The result was a good improvement. I then spent way too long getting the anti vibration pads back in place and I think was worse with them.
So all in all many thanks as this did improve my situation, but this Bosch is still ridiculous in its vibrations. I may just have to punt it.
By the way, what is an ideal washer if you have a wood floor?
Thanks once again,
Cheers!
LG and Samsung front loading washers are *designed/engineered* for WOOD floors.
LG overall---is a much simpler design (especially software)
These new washers will behave differently than the Bosch (and other washers) in this way...
1) 0-to-400 rpm:
Spin Cycle begins---low end rocking occurs---some spring tension sounds can be heard.
2) 400 rpm-to-top speed:
All vibration stops. Normal spin cycle duration (as if on a concrete floor)
3) 400 rpm-to-0
As the spin cycle ends---and the tub coasts to a stop---some noise/rattle can be heard briefly.
With the Bosch washer---shaking/vibration/walking/rattling/etc occurs for the *entire* duration of the spin cycle.
Edited by john63
Once again many thanks!
Cheers!
Followers 0
