Kenmore 70 series washer, 110.5761291 - after the spin cycle some water comes back into the tub
7 replies to this topic
#1 curling101
curling101
  • 4 posts
Posted 01 March 2012 - 04:37 PM
kenmore 70 series, 110.5761291 - after the spin cycle some water comes back into the tub
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 01 March 2012 - 05:53 PM
Water immediately comes back in, or there is water in it when you next go to use it ?
Something don't seem right with that model number - please check again
Ten Commandments for Reading Appliance Model Numbers :)
Posted Image Posted Image
#3 curling101
curling101
  • 4 posts
Posted 02 March 2012 - 09:49 AM
Water comes back in immediately. I got the model number from the washer inside the lid. It was from Sears Canada.
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 March 2012 - 09:56 AM
...110.5761291
... I got the model number from the washer inside the lid. It was from Sears Canada.
there's not a digit missing ?
#5 curling101
curling101
  • 4 posts
Posted 02 March 2012 - 10:30 AM
the model number is correct there is a space in the numbering. It appears exactly like: 110.576 1291
#6 curling101
curling101
  • 4 posts
Posted 02 March 2012 - 01:32 PM
I called sears parts department and they said that any model over 10yrs old they often take info on them off line. This model was purchased in '98. They could find this model number.
#7 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 02 March 2012 - 06:57 PM
Your drain hose seems to be air blocked and siphoning back into the tub.
Do you have rags or tape around the drain hose to keep in in place?
OR
Maybe a tight fitting drain hose?
OR
Maybe a sewer blockage and the water is not draining down the sewer?
#8 kdog
    RoughShod
  • 7,474 posts
Posted 02 March 2012 - 11:13 PM
Sometimes there are/were "Canadian" versions of certain models, by manipulating the number (adding a digit where the blank appears between the 6 and the 1) - get's referenced to an old Belt Driven machine(11057624). See if there is an access panel on the lower rear of machine that can be removed to view lower components.
