DACOR CPS130C Oven won't heat
DACOR wall oven failure oven CPS130C oven heating failure
2 replies to this topic
#1 revnormh
revnormh
  • 2 posts
Posted 02 March 2012 - 09:36 AM
Our DACOR CPS130C convection oven is about 15 yrs old and recently indicated F1 on the panel readout (relay circuit failure-?) and would no longer heat, but merely goes through a preheat indication and shuts down. I am an electronic technician and have removed the relay board, tested the main relay (T91P1D22-18F07) which tests good (contacts close upon energizing the coil) and I also tested the high temp limit switch & it is good(continuity). What am I missing? Is it the electronic control unit?
#2 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 04 March 2012 - 12:27 PM
Have you verified proper voltage to the oven?
www.eliteapplianceservice.org
#3 revnormh
revnormh
  • 2 posts
Posted 05 March 2012 - 01:15 PM
Yes, all voltages are proper. I finally checked other relays on the relay board, found a shorted diode, which was replaced (perhaps it shorted during one of my tests), re-installed all components and then went through all the tests in the ERC Quick Test from the diagnostic manual. This seemed to fix things as the oven now works :blinky:
Also tagged with one or more of these keywords: DACOR wall oven failure, oven, CPS130C, oven heating failure
