Maytag Laundry Centre SE1000 error code E-2
3 replies to this topic
#1 KimOler
KimOler
  • 1 posts
Posted 02 March 2012 - 11:32 AM
dryer is not working. error code e2 is appearing. Repairman (experienced but not computer-savvy for the internet) says he thinks the probelm could be either:
the relay board, the touch pad, the door switch or the motor relay.
thank you for any advice-
Kim
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 02 March 2012 - 11:53 AM
Has this Dryer worked OK for you up till now at this location ?
Does the Drum Motor work ?
Check & reset your House Circuit Breakers.
Check for 120v & 240v at the Wall Outlet & at the Dryer Power Cord Terminal Strip
Normal Operation:
The degree of dryness automatically selected will be normal dry and "E2" will appear in the display.
By pressing the "More" pad, "E3" will appear in the display and the control will operate at a "more dry" degree of dryness.
By pressing the "Less" pad, "E1" will appear in the display and the control will operate at a "less dry" degree of dryness.
#3 Scottthewolf
Scottthewolf
    Senpai
  • 2,942 posts
Posted 02 March 2012 - 03:03 PM
Please move this topic to the Laundry forum.
Scott Wolf
#4 kdog
    RoughShod
  • 7,466 posts
Posted 02 March 2012 - 11:43 PM
:thumbsup:
