  • Announcements
Darla
Kenmore Model no. 110.21202010 Washer won't start; just clicks
9 posts in this topic
My less than 2 yr old Kenmore washer 110.21202010 just makes a clicking sound when I push the start/pause button. I've tried the following:
  • Unplugged and plugged it back in
  • Pushed start button twice (it's suppose to reset it)
  • Completely replaced the lid switch ($54 wasted)
  • Screamed and cursed at it
  • Prayed
Nothing has worked thus far. I would like to completely take out that cursed lid lock, but will settle for just getting the machine up and running. (Found out I'm not a fan of doing laundry in the bathtub.) I don't think this machine has error codes; no digital displays and the lights don't seem to be flashing in any pattern. Maybe its something screwy in the electrical panel? How would you know? I do have some kind of voltage reader thingy but not sure how to use it.
Any help will be GREATLY appreciated!!
... I don't think this machine has error codes;
yes, it does, but it's a complicated sequence to enter the Service Modes and obtain Error Codes,
and Manual Test Modes.
Kenmore washer 110.21202010 bult by Whirlpool
Here's some info from the 21 page Tech Sheets - W10280489.pdf
ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode (plugged in with all indicators off).
2. Perform the following sequence of movement using the cycle selector knob.
NOTE: AFTER RESET, sequence “a” through “e” must be completed within 6 seconds.
RESET - Rotate cycle selector knob counterclockwise one or more clicks to clear sequence.
a. Rotate cycle selector knob clockwise one click and wait ½ second.
b. Rotate cycle selector knob clockwise one click and wait ½ second.
c. Rotate cycle selector knob clockwise one click and wait ½ second.
d. Rotate cycle selector knob counterclockwise one click and wait ½ second.
e. Rotate cycle selector knob clockwise one click.
 Successful activation of Diagnostic Test Modes will be indicated by all status LEDs
(except for Lid Locked) flashing ON and OFF in half-second intervals.
NOTE: LED names may vary between makes and models.
Legend: = ON = OFF
FAULT CODE DISPLAY MODE (Pgs 6–7)
To access fault/error codes, perform steps 1 and 2 of Activating the Service Diagnostic Test Modes.
Turn the cycle selector knob until the status LEDs correspond as follows:
 “Done” LED On
Press the START button to enter Fault Code Display Mode. The status LEDs flash on and off.
1. To view last 4 fault codes:
 Turn cycle selector knob clockwise to view fault codes in the order of most recent to oldest.
(Refer to Fault/Error Code charts on pages 6 & 7.)
NOTE: A fault/error code will be removed from memory if it does not reoccur after 10 consecutive wash cycles.
Whirlpool
Vertical Modular Washer L-84
for Tech Sheets and Service Manuals and other perks, become an Apprentice
Thank you Samurai!
Would you happen to have pp 6-7 of those tech sheets? This is the most helpful site; I'm so thankful you won't have to spill your entrails on my clean floor.
Darla
here's the jpg scans of those (2) pages
(not as good as the available original (21) page PDF file)
The tech sheet is in a pouch behind the front panel, has all these procedures in it and more.
You'll probably also want to check out these posts at my blog:
Diagnostic mode with video ==> http://appliantology...lar-washer-vmw/
Basic training on this washer, photos and especially the comments from other techs ==> http://appliantology...g-in-albany-ny/
United Samurai Beer Fund ==> http://beer.fixitnow.com/
How to replace the lid switch ==> http://appliantology...ool-vmw-washer/
Thank you soo much most honorable Samurai!
You have been so helpful; we haven't had time yet to try all of the info you sent, but you have given us so much more info than we found anywhere else. I'm recommending you to all my friends and sharing your site on face book!
Mucho domos, Darla! And be sure to like our Facebook page ==> http://facebook.com/fixitnowsamurai
Samurai,
Thanks again for how helpful you've been. With your help my hubby diagnosed the problem...it's the control panel, the circuilt that controls the lid lock is shorted out. It even is black where it shorted out. Grrr. I hate that cursed lid lock any way and we've now poured around $100 into a washer I don't even like. Now if we want to fix it it'll cost another $117.
Samurai, is there ANY way we can bypass the lid lock on this machine? I hate it, hate it, hate it. It's a totally unnecessary part and now I can't run my washer because the circuit for it is fried. Any advice would be appreciated.
Darla
... we've now poured around $100 into a washer
... is there ANY way we can bypass the lid lock
1) if the part had been purchased from RepairClinic, it could be returned for a refund :whistling:
2) Controller needs to see the Lid "lock & un-lock" before and after every Wash cycle.
