  • Announcements
Sign in to follow this
Followers 0
jaman
Maytag gas dryer LDG6914AAE ...no heat
5 posts in this topic
dryer drum turns but no heat.... checked continuity on ignitor, thermal fuse, gas valve coils, flame sensor, and hi-limit safety t-stat( on top of burner cone). All showed no break in the circuit. Any further tests I need to do??
the ignitor does glow for about 10 sec and then it goes off....
my assumption now is that the gas solenoid coil(s) are bad.....am I on the right track?
yes
http://www.repairclinic.com/referral.asp?R=154&N=3479
Followers 0
