Have a Kenmore/Whirlpool electric dryer about 10-15 years old. Ran, but did not heat. Followed your guidelines, checked the power coming in, getting 240V and 120 on the motor. Checked continuity on the fuses and thermostats. Found a thermostat (of course the hardest one to get to) on the metal bracket enclosing the heater coil to be bad. Got a new kit (came with both thermostats) popped it in and it worked. Ran one load of clothes, nice and dry. Put in another load this morning, no heat. Jumped the replaced the new thermostat and the coils heat up.
What can be causing the thermostat to fry?
Mike
Whirlpool/Kenmore 110 63012101 electric dryer thermostat keeps fryin'
#1
Posted 04 March 2012 - 02:28 PM
#3
Posted 04 March 2012 - 05:36 PM
#4
Posted 04 March 2012 - 07:19 PM
installed both in their correct locations ?[indent=1]
... Got a new kit (came with both thermostats)
- kdog likes this
#5
Posted 04 March 2012 - 11:30 PM
Perhaps there is a short in the heater assembly?
#6
Posted 04 March 2012 - 11:49 PM
perhaps ...
... Perhaps there is a short in the heater assembly?
There should be no continuity to chassis
OR
Run the Dryer in an Air-Fluff, no-heat cycle
make sure there is no heat
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
#7
Posted 05 March 2012 - 04:05 PM
Any suggestions to find a short or should I bite the bullet and get a new dryer?
#8
Posted 05 March 2012 - 05:37 PM
Post the normal Vent temperatures
#9
Posted 05 March 2012 - 10:17 PM
I went to my used appliance shop and the guy was super nice and gave me a used heating element unit to try. After installing it, no heat. So I checked it (should have done that first) and the first part toward the front (white with two prongs that are directly part of the coils) has no resistance. On the original heating element which keeps blowing thermostat but does heat up if I jump it, the ohm reading is about 10.
It appears that the white part is not replaceable, wish I could swap it. But is 10 ohms a normal reading?
Thanks.
#10
Posted 05 March 2012 - 11:33 PM
yes... is 10 ohms a normal reading?
- kdog likes this
Also tagged with one or more of these keywords: electric thermostat, no heat
Appliantology Appliance Repair Forums →
The Laundry Appliance Repair Forum →
Miele dryer T-1515Started by certified tech group 51, 08 Dec 2012 |
Enrolled Student's Classroom →
BOSCH DRYER WTA3510US Not heatingStarted by deanfaw1, 04 Oct 2012 |
GE Dryer M# DPXH46GA2CCStarted by Cactus Bob, 29 Aug 2012 |
Hotpoint NBXR453GVOWW gas dryer won't heat upStarted by ScottVan, 12 Mar 2012 |
The Kitchen Appliance Repair Forum →
Whirlpool microwave - no heat. GMH6185XVS1Started by Tarheel Technician, 29 Feb 2012 |
