LG Front Load WM2077CW, won't spin
5 replies to this topic
#1 Brooke Falconer
Brooke Falconer
    Ikkō-ikki
  • Master Appliantologist
  • 40 posts
  • Flavorite Brew:Heif
Posted 06 March 2012 - 11:10 AM
Hi HI,
I have an LG Front Load, complaint is that it won't spin. Customer says she is getting an E0 code. Any ideas where to check. The only experience I have with these machines is cleaning gunk out of the pump.
#2 john63
john63
  • 1,411 posts
Posted 06 March 2012 - 11:17 AM
<<<Customer says she is getting an E0 code.>>>
Not a valid error.
If the error is "OE"----likely a failed DRAIN MOTOR.
http://www.repaircli...EA2001D/1266821
If the error is "LE"---likely a failed HALL EFFECT SENSOR.
http://www.repaircli...KW2002A/1268238
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 RegUS_PatOff
  • 30,262 posts
Posted 06 March 2012 - 12:49 PM
EO is not a valid I/O error
maybe an EIE I/O :D
#4 Brooke Falconer
Brooke Falconer
    Ikkō-ikki
  • 40 posts
Posted 06 March 2012 - 09:27 PM
Oh RegUs, you are quick this morning! I tried to post but my Wi-Fi crapped out. I decided I am just going to make things up from now on just to come chat with you guys here, I love this board!
Anyway, it was an 0E, drain motor, after trying unsuccessfully to try and clean drain pump, I ordered a new one (another gong show in the ordering process, up here LG only wants to sell parts to LG techs....problem is we have one (1!!!!) for all of vancouver. Crazy!) Anyway, after wedging my self into the back of the laundry closet, prying out the pump, checking for debris, putting the pump back together-oh did i mention it was stacked- slicing my hands 2-3 times on the razor like edges our manufacturers think is funny, and calling around for over an HOUR to find a pump, it is getting delivered tomorrow morning. Sometimes I wonder why I like this job?????
Take care guys....until next time :thumbsup:
#5 RegUS_PatOff
  • 30,262 posts
Posted 06 March 2012 - 10:19 PM
... up here LG only wants to sell parts to LG techs....
http://www.repaircli...R=154&N=1266821
#6 john63
john63
  • 1,411 posts
Posted 06 March 2012 - 10:51 PM
<<<after wedging my self into the back of the laundry closet, prying out the pump, checking for debris, putting the pump back together-oh did i mention it was stacked>>>
If you can do all of that (shoehorning yourself into a closet)...
Then you'll be fine replacing the DRAIN MOTOR from the *door opening*.
On stacked units---this is the most pain-free method.
Open door
Remove door gasket outer CLAMP and peel back GASKET into stainless steel tub
Remove lower left pump clean-out strainer COVER.
Remove a single phillips screw---and pull out the plastic HOUSING that is part of the pump clean-out strainer
Looking at the pump clean-out strainer (at floor level) you'll see 2 phillips screws above the strainer handle---remove both screws
Cut a section of 2x4 wood---approximately 5 to 6 inches length
Place the 2x4 wood block between the TUB and the FRONT COVER of the washer---this will give you additional space to access the DRAIN MOTOR---by keeping tub assy pushed rearward.
Reach down to the PUMP ASSY---using your finger---find the RELEASE TAB and depress it. This allows sliding the entire PUMP ASSY away from it's mounted position and be turned by hand.
There are 3 screws which secure the DRAIN MOTOR to the pump housing---remove them and pull off the drain motor.
Re-install & test washer.
NOTE: One or two of the DRAIN MOTOR screws can be accessed from the *hole* where the STRAINER was located.
TIP: Wear PVC-coated work gloves
Edited by john63, 07 March 2012 - 12:13 AM.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
How to replace the drain pump in an LG front load washer stacked laundry unit
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 06 March 2012 - 11:30 PM
The need for this repair could be something obvious like the washer isn't draining (though other things can cause that, too, like a plugged drain hose) or something less obvious like an OE error code.
First step is to come git you a new drain pump with a 365-day return policy ratcheer ==>...
Read Full Entry →
