LG wm1832cw will not rotate
lg
8 replies to this topic
#1 wrvdb
wrvdb
  • 5 posts
Posted 06 March 2012 - 08:31 PM
This is my first post. Please help, family coming in tomorrow..
LG wm1832cw washer will not rotate (most of the time). Right now I have the rotor and stator off and it rotates smooth. With the motor on and trying to rotate it seems electrically locked, motor hums, but no rotation (i can use force to spin it). The brearker does not trip. Thanks in advance..
#2 wrvdb
wrvdb
  • 5 posts
Posted 06 March 2012 - 08:47 PM
update, put the motor back on. when the motor energizes to rotate, it locks up. when i manually assist it, it will rotate, but grind.
#3 wrvdb
wrvdb
  • 5 posts
Posted 06 March 2012 - 10:15 PM
Update #2: how do you pull the back metal plate off (18 outer bolts removed, 5 inner bolts inplace). It is the plate that houses the bearings. I have removed the 18 outer bolts, and have tried to pry it off (lightly), but it will not come off. I assume it has a gasket, but do not see one in the diagram? (drum assembly http://www.appliance...g/wm1832cw.html
#4 john63
john63
  • 1,411 posts
Posted 06 March 2012 - 10:18 PM
<<<when the motor energizes to rotate, it locks up>>>
<<<it will rotate, but grind.>>>
These symptoms are indicative of a failed HALL EFFECT SENSOR.
Usually the Control Panel will show an "LE" error as well.
http://www.repaircli...KW2002A/1268238
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#5 wrvdb
wrvdb
  • 5 posts
Posted 06 March 2012 - 10:25 PM
Thought the same thing, but no error code given? What should the typical ohn reading be for a hall sensor?
#6 john63
john63
  • 1,411 posts
<<<how do you pull the back metal plate off >>>
Do not remove the rear metal plate or the bolts---re-install them.
To replace the HALL EFFECT SENSOR...
Remove the 17mm bolt from the ROTOR
Remove the 10mm bolts which secure the STATOR ASSY (large copper windings) to the tub.
Carefully lower the STATOR ASSY and pry off the HALL EFFECT SENSOR from the *single* locking tab.
Install new HALL EFFECT SENSOR and reassemble
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#7 wrvdb
wrvdb
  • 5 posts
Posted 06 March 2012 - 10:28 PM
I have it in hand and will replace. I just never had an error code.
#8 john63
john63
  • 1,411 posts
Posted 06 March 2012 - 10:30 PM
<<<What should the typical ohn reading be for a hall sensor?>>>
Try this first...
Have a helper look at/observe the washer stainless steel tub through the door glass.
Press and hold the SPIN SPEED and SOIL LEVEL buttons
Press the POWER button and release all three buttons
Wait until the door locks (single "click" sound)
Press the START/PAUSE button once
Is the tub rotating/tumbling and the drain motor running?
If the tub "jiggled/wobbled" momentariliy and froze---replace the HALL EFFECT SENSOR.
If the tub turns/tumbles slowly and somewhat haltingly---and the MOTOR g-r-o-w-l-s and g-r-i-n-d-s---replace the HALL EFFECT SENSOR
Edited by john63, 07 March 2012 - 12:10 AM.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#9 kdog
    RoughShod
  • 7,428 posts
Posted 07 March 2012 - 02:05 PM
Link to Part:  http://www.repaircli...Number=WM1832CW
Rotor-Position-Sensor-6501KW2002A-010490
Also tagged with one or more of these keywords: lg
