Whirlpool model # WFG371LVS gas oven wont stay on
5 replies to this topic
#1 tzd316
tzd316
    Ikkō-ikki
  • Chief Appliantologist
  • 37 posts
  • Flavorite Brew:coke cola
Posted 07 March 2012 - 08:14 PM
Hi i have a whirlpool model # WFG371LVS. Oven wont stay on ignitor comes on oven fires up for 5 seconds then shuts off. Then tries to start againe stays on for 5 seconds and you can here the spark module clicking.looked at clock it's displaying 100 degrees please help thanks
  • 24,218 posts
Posted 09 March 2012 - 08:17 PM
There are three service pointers pertaining to this problem that you need to read:
1. https://secured.whir...30?OpenDocument
2. https://secured.whir...5f?OpenDocument
3. https://secured.whir...f3?OpenDocument
#3 RegUS_PatOff
  • 30,201 posts
Posted 09 March 2012 - 08:45 PM
has this Oven worked OK for you up till now at this location ?
#4 tzd316
tzd316
    Ikkō-ikki
  • 37 posts
Posted 11 March 2012 - 08:26 PM
Thanks for the three service pointers pertaining to this problem. someone gave me this oven they said it was working. Everything else works fine so i dont know thanks for the help
#5 RegUS_PatOff
  • 30,201 posts
Posted 11 March 2012 - 08:33 PM
Wall Outlet must have proper ground and proper polarity (L1 & Neutral)
#6 Chat_in_FL
Chat_in_FL
    Senpai
  • PipPipPipPip
  • 896 posts
  • Flavorite Brew:Variety is the spice of life!
Posted 12 March 2012 - 07:05 AM
I would suspect the Spark_Module from these symptoms. Look at the strength of the spark at both the broil and bake ignitors. If both are weak, this is a good sign the spark module is bad.
Mother Teresa
