Whirlpool dryer ,LER8648PW0 Not getting hot enough!
2 replies to this topic
#1 Patch
Patch
  • 6 posts
  • Flavorite Brew:all
Posted 07 March 2012 - 09:53 PM
My dryer wasn't hot at all removed heating element and sure enough it was bad, replaced element now dryer is still not getting hot enough, its taking sometimes 3 or 4 cycles to dry a load...Any ideas where to look next?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 March 2012 - 11:43 PM
check & clean your Venting System
Dryer Vent
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
 $ 4.99 sometimes on sale for $ 2.99
#3 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 08 March 2012 - 06:36 AM
Remove the dryer exhausr vent and run one load on Time Dry at 50 minutes as a test. Then do what RegUS_PatOff instructed above.
