Maytag Performa model PAV2300AWW Full of water.
Maytag washer water
1 reply to this topic
#1 Kennykillers
Kennykillers
  • 1 posts
  • Flavorite Brew:Miller lite
Posted 08 March 2012 - 06:05 PM
Washer will agitate w/ terrible noise. At end of wash cycle will not drain. Spin and rinse cycle get no response at all as if unplugged. Any help is appreciated. thanks Andy
#2 appl.tech.29501
appl.tech.29501
  • 8,019 posts
Posted 10 March 2012 - 04:15 PM
Is the noise a "screeching noise" if so then your pump is probably bad. If you remove
the belt from the bottom of the machine the pump pulley (small aluminum pulley)
should turn freely in both directions. It's probably binding in the spin cycle causing the
motor to trip on its thermal over load.
If the noise sounds like rocks grinding then your transmission is bad.
Drain Pump link if needed.
http://www.repaircli.../356465/1480289
www.eliteapplianceservice.org
