Bosch washer model WFMC2011UC doesn't complete cycle
Bosch Washer Front load Fails Stops Cycle WFMC2011UC
2 replies to this topic
#1 cayenne1011
cayenne1011
  • 3 posts
Posted 08 March 2012 - 11:04 PM
I have a WFMC2011UC someone gave me which, when looking at the unit, appears to be in pretty good condition. I hooked it up and tried running through a cycle but it failed after about 12 min. It stops at 54 min remaining on a permanent press setting. First, the panel worked as expected with all the lights and settings functional. When pushing the start button it begins to fill and the drum starts to agitate. After the filling is complete, the drum continues to agitate for a little while, then it stops. The water drains and the pump continues its function for about one minute and stops. Well, after I first noticed the problem, I ordered a new control board and installed it today. The same thing happened and it was pretty discouraging. Now I read that someone else was having the same problem, tried the same fix and it didn't work for them either. Eventually, they ordered and replace the motor control board and that worked for them. There was a PDF on your older sight for my unit but it's no longer available. I think it was named wfmc2100uc.pdf. Is there any way I can get a copy of it? Does the motor control panel seem like a logical next step?
Any advice or suggestions would really be appreciated.
Thank you,
#2 sh2sh2
sh2sh2
    Sōhei
  • 213 posts
  • Flavorite Brew:yeunling
Posted 09 March 2012 - 05:05 PM
there should be a number after the UC in you model number, after the /
#3 cayenne1011
cayenne1011
  • 3 posts
Posted 12 March 2012 - 01:32 PM
The full number is WFMC2100UC14045036. It's also showing 900 rpm
Also tagged with one or more of these keywords: Bosch, Washer, Front load, Fails, Stops, Cycle, WFMC2011UC
