Whirlpool Dryer LGC8858EQ1 stinks
Whirlpool LGC8858EQ1 spin smell belt dryer
6 replies to this topic
#1 Tony Boxacannoli
Tony Boxacannoli
  • 6 posts
  • Flavorite Brew:Chocolate Milk
Posted 10 March 2012 - 03:26 PM
Our very old [1997?] Whirlpool LGC8858EQ1 dryer stinks.
By "stink" I mean it actually smells....I am thinking its because the belt has quit and the it just getting smoked by the motor/pulley rotation/friction?
When we turn on the dryer, it "sounds" like it wants to spin [and actually did at some point] , but it doesn't now. This lack of rotation is accompanied by a horrid smell....I think its the drive belt:
http://www.repaircli...mber=LGC8858EQ1
Correct diagnose by a noob?
#2 RegUS_PatOff
  • 30,689 posts
Posted 10 March 2012 - 03:50 PM
Remove the Belt and try turning the Drum by hand.
Try turning the Motor Shaft by hand.
Does it turn easily, smoothly ?
#3 Tony Boxacannoli
Tony Boxacannoli
  • 6 posts
Posted 11 March 2012 - 05:04 PM
Today, I removed the drum.....vacuumed out all the lint, paper clips, silly bandz, etc that was in the housings/frame...and found $4.72 in assorted change.
I tried to rotate the motor..it rotated freely BUT emitted a squeak.
I put it all back together again, rotated it by hand...movement seemed "ok".
I plugged it it [gas connection NOT made up; venting NOT made up] and gave it a spin.
It spins, but that squeak I heard in the manual test is back.
What this tells me it is not the belt [although it still *could* be at fault, just not primary failure], but rather the motor...possible the bearings?
If i had to pinpoint the location of the squeak, I'd say it came from the back of the motor assembly
What say you?
#4 RegUS_PatOff
  • 30,689 posts
Posted 11 March 2012 - 06:48 PM
http://www.repaircli...sp?R=154&N=2584
#5 jumptrout
jumptrout
  • 1,192 posts
  • Flavorite Brew:Coors Light
Posted 11 March 2012 - 06:51 PM
Does the wheel on the tension roller move easily?
Part number: AP2911909
#6 kdog
    RoughShod
  • 7,433 posts
Posted 11 March 2012 - 07:34 PM
If you're gonna be in there changing that failed motor, go in armed with this
#7 Tony Boxacannoli
Tony Boxacannoli
  • 6 posts
Posted 11 March 2012 - 09:18 PM
It does move easily....not as easily as say a roulette wheel, but easy.
When I removed the drum, that piece was laying on the frame floor - not attached to anything.....after watching that movie, I figured nothing was busted....I was kinda brutal removing the drum ~ didn't really know how it came out.
One of the "fins" in the drum [that help move the clothes along] was black..the other 2 were white.
As long as I had the drum off...I removed the darkened fin.
The cause of discoloration was 0.93¢. ....a nickel was just about worn smooth.
I had considered that kit.
The belt is from 1997 ...how much longer do you think it has left...a day... a week...a decade?
Anyone's guess really.
Cheap insurance I think.
Also tagged with one or more of these keywords: Whirlpool LGC8858EQ1, spin, smell, belt, dryer
