Maytag MDG6000BWW Gas Dryer making funny sound, overheating
#1
Posted 10 March 2012 - 03:33 PM
Do you think the motors going or could it be belt or pulley that's putting undue stress on the motor and causing it to overheat?
I had the drum glides replaced last summer (7/2011).
#2
Posted 10 March 2012 - 03:55 PM
blower.
Most likely your motor is going bad as well,
but have a look at the scraping first.
www.eliteapplianceservice.org
#3
Posted 10 March 2012 - 10:13 PM
Check and see if the Blower has stripped off on the motor shaft
http://www.repaircli...mber=MDG6000BWW
- Moostafa likes this
Le Chien Rouge
#4
Posted 11 March 2012 - 07:03 AM
#5
Posted 11 March 2012 - 02:36 PM
- Samurai Appliance Repair Man and jumptrout like this
Le Chien Rouge
#6
Posted 11 March 2012 - 08:47 PM
- kdog likes this
#7
Posted 16 March 2012 - 06:34 AM
How would I recognize if the blower has stripped off from the motor shaft?
#8
Posted 16 March 2012 - 07:02 AM
#9
Posted 16 March 2012 - 07:29 AM
Should be scuffed pretty good. If the drum was scraping
the metal on the bulkhead for an extended period
Of time the drum may have rough places that will
Prematurely where out the new glides.
Start with the felt
If the blower wheel is bad you will be able to
Turn it on the motor shaft with out the motor
Shaft turning.
#10
Posted 16 March 2012 - 12:12 PM
Dryer runs great and quiet with nothing it is. Drum will not move at all once I add the weight of wet clothes. Any ideas??
oops . I meant runs great when there is nothing in it
#11
Posted 16 March 2012 - 12:19 PM
Assuming that the belt was installed correctly
And the the motor is actually not running when
Under a load ...only humming.
#12
Posted 16 March 2012 - 02:40 PM
Does it turn easily, smoothly ?
#13
Posted 16 March 2012 - 06:37 PM
- kdog likes this
#14
Posted 17 March 2012 - 08:56 AM
#15
Posted 17 March 2012 - 09:09 AM
try running a no-heat cycle to see if the noise is the same,
and if it completes a cycle, or shuts off soon
#16
Posted 17 March 2012 - 09:51 AM
#17
Posted 18 March 2012 - 06:57 PM
- kdog likes this
Also tagged with one or more of these keywords: Maytag, gas dryer, MDG6000BWW, scratching noise, overheat, burnt smell on clothes
