lg wm2501HWA front load washer counterweight came off
lg washer counterweight
2 replies to this topic
#1 fourlee
fourlee
  • 2 posts
  • Flavorite Brew:coors
Posted 14 March 2012 - 11:21 PM
I bought a LG true stream front load washer (model wm2501HWA) two years ago. About six months ago it make a lot of rumbleing noise when at spinning cycle. It turns out the counterweight on the top side of the drum slided out of the mounting post. I remounted the counterweight and seems fixed the noise problem until now. I just checked and is the same counterweight came off the post problem. Is there anyway to permanently mount the counterweight so it would not slide out?
Fourlee
#2 john63
john63
  • 1,411 posts
Posted 14 March 2012 - 11:52 PM
A rare occurrence.
Wrap electrical tape around each mounting bolt---5 times---at the end of the thread near the bolt head (not near the bolt tip).
Re-install the bolts with---either a powerful drill or socket set (10mm)
The electrical tape should help expand the TUB WEIGHT studs---slightly---for better retention.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3 fourlee
fourlee
  • 2 posts
Posted 15 March 2012 - 10:14 PM
Thanks for the advice. It turns out the four stubs was stripped and not able to screw all the way. With the electrical tape on the bolts. I was able to screw them all the way into the stub. Now the stubs are expands like the bottom counterweight mounting studs.
It works fine for now. If this come off again, I will try to use poxy glue to glue them down for good.
Also tagged with one or more of these keywords: lg, washer, counterweight
How to reattach the top counterweight in an LG washer that keeps coming loose and making a rumbling noise
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 16 March 2012 - 07:27 PM
A rare occurrence.
Re-install the bolts with---either a powerful drill or socket set...
Read Full Entry →
