Amana NED7200TW Dryer no heat, problem with cycling thermostat?
37 replies to this topic
#21 RegUS_PatOff
  • 30,690 posts
Posted 17 March 2012 - 04:13 PM
there must be 240v from Black to Red
Has this Dryer worked OK up till now at this location ?
Have you re-set your House Circuit Breakers ?
#22 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
  • Flavorite Brew:yeunling
Posted 17 March 2012 - 05:02 PM
if there is no 240 from black to read but there is 120 from black or red to white then one of the legs is open and 120 is feeding through the dryer to the other leg...unplug the dryer and test the outlet by itself, you wil find one leg has no power. Lesson learned. When you find nothing wrong with the appliance look elsewear for the problem. Time to call in the electrician
Edited by sh2sh2, 17 March 2012 - 05:03 PM.
#23 triggerhappy007
triggerhappy007
  • 15 posts
Posted 17 March 2012 - 05:20 PM
Yes, dryer worked for almost 3 years at this location
I did reset my circuit breaker before taking the dryer apart.
At the outlet, theres 125V from each side, and 250V when both sides are connected.
#24 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
Posted 17 March 2012 - 05:35 PM
but at the terminal block you said there was 0 from black to red? if so there must be a opening in the power cord or the outlet is not making good connection with the power cord?
#25 triggerhappy007
triggerhappy007
  • 15 posts
Posted 17 March 2012 - 07:03 PM
I noticed I hooked up the power cord wrong when I first installed it. I mixed the red and black wires up and had the ground from the power cable going to the white. Now I redid the cables so the ground from the dryer is going to the white, red to red, black to black, and ground from the power cord going to the ground on the machine.
It's getting 250V from red to black of the terminal block. Now, the dryer doesn't turn on at all.
#26 triggerhappy007
triggerhappy007
  • 15 posts
Posted 17 March 2012 - 07:38 PM
I just checked red to black at the terminal block and it's only 125V now.
#27 john63
john63
  • 1,411 posts
Posted 17 March 2012 - 07:40 PM
<<<Now, the dryer doesn't turn on at all.>>>
If the 2 low voltage plugs (for the front control panel) were removed from the MAIN BOARD during your various tests---verify that both have been re-installed (black and white multi-pin connectors).
Forgetting to re-install these 2 plugs will result in a "dead" dryer (no lights at all).
If the Control Panel "awakens" (lights are on)---verify that the DRUM BELT is installed (dryer will not start with a disconnected/broken belt).
Edited by john63, 17 March 2012 - 08:02 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#28 RegUS_PatOff
  • 30,690 posts
How could it have been working for 3 years if the Power Cord was connected wrong from the original installation ?
Is this a 3 wire OR 4 wire Outlet ?
Is this a 3 wire OR 4 wire Power Cord ?
If the Dryer isn't wired correctly, it could blow the Controller.
#29 triggerhappy007
triggerhappy007
  • 15 posts
Posted 17 March 2012 - 08:02 PM
I double checked to see if they were connected and they were.
RegUS,
I'm not sure why it worked, but it did. I have 4 wire outlet and a 4 wire power cord. It's weird, I checked the red and black at the terminal and it was 250V, then I assembled the dryer together and check it, but it's only 125V now.
#30 john63
john63
  • 1,411 posts
Posted 17 March 2012 - 08:09 PM
Possible faulty POWER CORD.
Check continuity of each wire-to-the-plug terminal.
Bend/flex the plug while testing each wire to see if a "break" in continuity occurs.
If it does---new POWER CORD needed.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#31 jb8103
jb8103
    Kohai
  • Chief Appliantologist
  • 459 posts
  • Flavorite Brew:Ginger ale
Posted 17 March 2012 - 10:39 PM
Can you measure voltage across black/blue of the heater relay while machine runs on a heating cycle ?
Also measure each of the black/blue to a good ground
I do believe I've learned a thing or two around here - that's where I was going next. (ed.: oops, late post)
Edited by jb8103, 17 March 2012 - 10:40 PM.
First, do no harm.
#32 RegUS_PatOff
  • 30,690 posts
Posted 18 March 2012 - 01:23 AM
Do anther test at the Outlet...
May need more of a "load" than just a volt-meter.
If you have a table lamp, etc
Try test-wiring the table lamp to each of the 120v connections ONLY:
Black & Neutral
Black & ground
Red & Neutral
Red & ground
#33 sh2sh2
sh2sh2
    Sōhei
  • 226 posts
Posted 18 March 2012 - 08:15 AM
The reason the dryer might be dead now is when you rewired the terminal block you may have moved the working leg from L1 to L2 so now the controls dont have power. Try wiggiling the plug in the outlet and see if voltage comes and goes, shine a light into the terminals in the plug and see if they are shiny or burnt
#34 triggerhappy007
triggerhappy007
  • 15 posts
Posted 18 March 2012 - 09:49 AM
This is probably the problem. I can see that one side is not making very good contact even though my test probe read voltage. I will replace the outlet today and see how it goes. Thank you everyone for your help.
#35 jb8103
jb8103
    Kohai
  • 459 posts
Posted 18 March 2012 - 02:31 PM
And check your power cord wiring against this, from the oracle himself:
http://fixitnow.com/.../dryercords.htm
First, do no harm.
#36 Samurai Appliance Repair Man
  • 24,698 posts
Posted 18 March 2012 - 07:46 PM
Dayyam, the page is so old it blew dust in my eyes when I clicked the link! And what grade-schooler designed that page layout? :sillytongue:
#37 triggerhappy007
triggerhappy007
  • 15 posts
Posted 19 March 2012 - 12:02 AM
Replaced the outlet and everything works now. Thanks again for all your help.
#38 john63
john63
  • 1,411 posts
Posted 19 March 2012 - 12:17 AM
"You Know I'm Glad---I Need The Rest!"
Deputy Sam Gerard---to Dr. Richard Kimball in a scene at the end of the movie: "The Fugitive"
Edited by john63, 19 March 2012 - 12:19 AM.
To eliminate:
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
Troubleshooting tip for fixing an Amana NED7200TW (Samsung-built) electric dryer that's not heating
By Samurai Appliance Repair Man in Samurai Appliance Repair Man's Blog, on 16 March 2012 - 09:44 AM
Being a Samsung-built dryer, this one can throw you a curve ball if you're not used to thinking like a Korean. Fortunately, Doctor John is fluent in Korean Dryerese and sets us on the right track:
A SAMSUNG-built dryer.
The...
Read Full Entry →
From: Amana NED7200TW Dryer no heat, problem with cycling thermostat?
By kdog in kdog's Blog, on 16 March 2012 - 12:42 AM
View Posttriggerhappy007, on 16 March 2012 - 12:38 AM, said:
[Yes, I did reset the breaker and checked the voltages. Here's the wiring diagram:
Source:...
Read Full Entry →
0 members, 1 guests, 0 anonymous users
