Fisher&Paykel,glw15,washer, need a tech sheet with codes
#1
Posted 16 March 2012 - 12:25 AM
#2
Posted 16 March 2012 - 12:30 AM
3 SIZE SETTING MODE
To set the size switch, turn the power on at the power point and off at the console. Press and hold
WASH TEMPERATURE SETTING UP then press POWER. EcoSmart® will give 4 short beeps
and the pattern of LEDs will change.
To lock the size into memory.
• Press SPIN SPEED UP, the SPIN HOLD LED is on for 7.5 / 8.0kg (650mm wide).
• Press POWER to confirm the setting and also exit this mode.
If the size setting is wrong, EcoSmart® will have the following settings incorrect: -
• The Auto Water Levels chosen may be incorrect.
• The High Water Level may be incorrect by as much as 40mm.
• The wash profiles may be incorrect resulting in poor wash performance or vigorous wash
actions causing tangling, splash over or excess linting.
• Water saver settings.
Also tagged with one or more of these keywords: tech sheet
