Tired of guessing on service calls?
Sign in to follow this
Followers 0
Joce1Maya2
Fisher&Paykel,glw15,washer, need a tech sheet with codes
2 posts in this topic
Replaced the board water pump and lid lock. Comes on but does nothing else. Looking for a way to "size" or "Program" the board. I need a tech sheet with diagnostic codes. Thanks
for service manuals and other perks, become an Apprentice
3 SIZE SETTING MODE
To set the size switch, turn the power on at the power point and off at the console. Press and hold
WASH TEMPERATURE SETTING UP then press POWER. EcoSmart® will give 4 short beeps
and the pattern of LEDs will change.
To lock the size into memory.
Press SPIN SPEED UP, the SPIN HOLD LED is on for 7.5 / 8.0kg (650mm wide).
Press POWER to confirm the setting and also exit this mode.
If the size setting is wrong, EcoSmart® will have the following settings incorrect: -
The Auto Water Levels chosen may be incorrect.
The High Water Level may be incorrect by as much as 40mm.
The wash profiles may be incorrect resulting in poor wash performance or vigorous wash
actions causing tangling, splash over or excess linting.
Water saver settings.
Followers 0
