Daveb1972
Hello all, looking for the service manual for this unit. I have a friend who's unit decided to blow the fuse, and seems ok after the replacement fuse has been installed, but I fear where one blown fuse is seen, many are near.
... I fear where one blown fuse is seen, many are near.
LG GM-L267BNRY
may not necessarily blow again . . .
blink.gif My eyesight isn't as good as it once was (see RegUS_PatOff
but from here it looks like your model number may be
LSC26905TT ?
LSC26905TT ?
And in case it is, I've PMed the manual to you. :thumbsup:
