PSS26SGPA GE died Company Coming Today! OMG
36 replies to this topic
#1 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 11:34 AM
I'm back at your mercy! You helped me fix my refrigerator last time - it's been clicking along, no problem. I'm cleaning the house for company, went to get a drink of water and I noticed....my bottle of water is warm! OMG! I looked at the temp on the display and it's 45 on the fridge and hot on the freezer side too! I run to the breakers and they are not flipped. I call my husband and comes home and we pull it out and the fan is running after we pull the back panel off at the bottom. The ice is all melting in the freezer. Where is the reset button? What are we going to do with the house full of company coming for the week?
HELP!
#2 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
  • Flavorite Brew:Killians Red
Posted 17 March 2012 - 11:58 AM
Is the compressor running? Is it hot/warm to the touch?
If not, unplug and access motherboard on rear...remove all plugs and remove board from holders.
Any obvious burnt marks or failed solders?
#3 tommytech
tommytech
    Sōhei
  • Master Appliantologist
  • 163 posts
  • Flavorite Brew:guiness
Posted 17 March 2012 - 11:59 AM
if you know where the compressor is,feel if its running or just clicks every few minutes. CAREFUL compressor may be hot. feel at the back wall inside freezer, any frost there?
#4 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 12:23 PM
Great - where's the compressor? I took the panel off to the main board......
There's no frost. Temp is 38 is the freezer.
Edited by allowingtoo, 17 March 2012 - 12:27 PM.
#5 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
Posted 17 March 2012 - 12:26 PM
Its that big ,black oblong object in the compartment where you found the fan...
#6 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 12:28 PM
oh. the thing with the fan running on the end of it. No it's cold.
#7 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
Posted 17 March 2012 - 12:32 PM
Not the condenser (round ,cage lookin wit the fan on the end) the compressor...solid black ,steel ,other end of compartment...
#8 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 12:42 PM
wouldn't you know my camera batteries are dead? all I have is a round black thing but I thought that held freon or something. It is labeled DC51C84RCU6 and then off to the side it says R134a
the 1C above may not be correct there's something over it.
Yep, if I Google R134a it's says Freon.
Where's that compressor?
Edited by allowingtoo, 17 March 2012 - 12:43 PM.
#9 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 12:54 PM
I take it back. That is it, isn't it?
http://www.repaircli...ber=PSS26SGPASS
#10 RegUS_PatOff
  • 30,272 posts
Posted 17 March 2012 - 01:03 PM
Compressor # 725
Evaporator Coils (inside Freezer) being held by Shield # 232
#11 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 01:19 PM
Well.....Board's burnt. But you knew that.
thank you.
:tinkerbell:
#12 RegUS_PatOff
  • 30,272 posts
Posted 17 March 2012 - 01:33 PM
depending on the first (2) characters of your Fridge serial number,
the MotherBoard may be covered under a Service Bulletin,
but must first also check to see if the Evaporator Fan runs OK.
#13 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 01:49 PM
FF doesn't stand for Frost Free?
#14 RegUS_PatOff
  • 30,272 posts
Posted 17 March 2012 - 01:53 PM
FF = March 2003
not included in the service bulletin for the "problematic" MotherBoards
#15 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 01:56 PM
Well, I appreciate the help.
It's going to be a LONG weekend. Nobody in town has this. Everybody is closed. Company is coming. BUT on the bright side - at LEAST we don't have to buy a new fridge.
Thanks again.
#16 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
Posted 17 March 2012 - 02:06 PM
Don't give up just yet...I see you are a merit apprentice. If you have a soldering gun, it is possible to clean up and resolder this joint, if only as a temporary fix.
Give it a shot....can't really do any more damage.
#17 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 02:36 PM
Oh I can solder, I do stained glass. But this? Hmm. I thought I attached that picture.https://plus.google....952721364942785
Edited by allowingtoo, 17 March 2012 - 02:41 PM.
#18 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
Posted 17 March 2012 - 02:40 PM
You'll need some electrical solder instead of the plumbing stuff I believe ya use for stained glass...
can't hurt to try...just might get a working fridge for the weekend :-)
#19 allowingtoo
allowingtoo
    Yamabushi
  • 85 posts
Posted 17 March 2012 - 02:46 PM
I'm just saying I can solder. That looks really fried.
#20 KurtiusInterupptus
KurtiusInterupptus
    B.M.F.
  • 1,470 posts
Posted 17 March 2012 - 03:08 PM
