kevinmac6591
G.E. DISHWASHER MODEL GSD6660G00SS NO WATER FILL
7 posts in this topic
NO WATER FILLS WATER FILL TIME IS SILENT THEN MOTOR RUNS TO SPRAY WATER AROUND BUT NO WATER BUT CYCLE KEEPS ADVANCING TO PUMP ETC.. PUT TEST CORD DIRECTLY ON WATER VALVE AND WATER ENTERS- SO WATER SUPPLY IS OK AND WATER VALVE IS OK-- INSTALLED NEW FLOAT SWITCH BUT NOTHING CHANGED STILL NO WATER ENTERS. ANY IDEAS APPRECIATED.
First, Check resistance of Water Valve.
A shorted Valve or a bad dual Zener protection Diode in the Harness, can blow the Controller...
otherwise, sounds like a bad Controller .
http://www.repairclinic.com/referral.asp?R=154&N=1026099
Main-Control-Board-WD21X10174-00724610.j .
Regus...that protection varistor, when it fails,will cause the unit to trip its breaker or fuse...as It provides a path from hot to neutral when it fails...
Either a bad board or broken wire...
... path from hot to neutral, through the Controller driver component... :woot:
although, if it "opens" or is disconnected,
there would no longer "spike" (caused by the Valve Coil) protection of the Controller.
installed the board and still no water fill put test cord directly on water valve one more time and water valve fills when tested this way. asked lady if when this problem first started if breaker tripped and she said no. could it be this transorb varitor thing and if so where is it locacted and what does it look like. thanks
Good thing you ordered the board thru the part link that Grand Master Reg posted for you because you can return it for a refund. :thumbsup:
You musta missed the link I posted in my preceding post. Answers all this and more!
