kenmore 110.23832100 washer won't drain completely... intermittant problem
kenmore washer
2 replies to this topic
#1 watdat0
watdat0
  • 2 posts
Posted 18 March 2012 - 09:46 PM
I have a kenmore 110.23832100 and i won't drain completely at intermitent times. On the timed load it consistently stops just before the drain part as it transitions to the rinse cycle. On the perm press cycle it does it with larger loads. This is wierd because the size of the load determines if it will fully drain and begin rinse cycle.
When this happens I can turn the knob to a rinse cycle and it will drain and spin fine.
The lid switch is fine and I have unplugged it to reset the timer. Any other suggestions?
Thanks, Jen
#2 kdog
    RoughShod
  • 7,428 posts
Posted 19 March 2012 - 02:05 AM
Sounds like a timer issue, mechanical timer (no "reset" feature)
http://www.repaircli...er=110.23832100
#3 watdat0
watdat0
  • 2 posts
Posted 23 March 2012 - 06:16 PM
Thanks! I will try it out and let you know:-)
