John in the OC
Maytag Sav4655EWW washer Not Draining
19 posts in this topic
This machine only rinses when I raise the lid. I will lift the lid in the middle of a cycle it drains and then rinses no problem. If I put the washing machine on Gentle or another cycle other than normal it sounds like a giant jet engine and will stop its self after a few minutes.
This problem was intermentent before but not it happens everytime we try to do laundry.
Thanks
Sounds like you may have something caught in the pump - not sure I follow the Lid thing though, with the lid lifted - the machine should not run at all - can you talk more about that ?
More info here: http://appliantology.org/topic/35690-maytag-atlantis-mav7600aww-making-loud-noise-during-agitate-and-spin-cycle/page__p__219904__hl__atlantis__fromsearch__1#entry219904
1 person likes this
It's not going through its cycle properly The only time I can get it to drain is if I move the dial to rinse or when i lift the lid up If I don't do this it remains full of water if I raise the lid and close it it drains and starts the rinse cycle
So if I watch the machine in the normal cycle and it get to the rinse and spin part it just rolls right through it washing away ok and leaves the tube full of water when it stops But If I lift then lid and then shut it when it shoud be in rinse mode, it starts to rinse spin and will complete the wash
i saw somthing like this once on a sav maytag... it was the timer... was never pausing to let the motor reverse to drain would just wash away... replacing the time fixed the machine i was working on
1 person likes this
But before we get too far, the original poster needs to look more at this roaring sound... possibly the tub bearing,seal leaking
Possibly more than one speed energizing in motor until tripping overload - diagram mentions a 4 position speed switch, can you try the various settings while using normal/delicate/perma press cycles ?
2 people like this
yes I have tried the Delicate Handwash and...wrinkle free The noise it makes is like "its trying to do something than just will shut down. I am then able to wait 15 minutes go out and put it on Normal was and it works This is was intermittent but now it happens all the time
post YouTube Video ?
1 person likes this
Thanks guy!
BTW - There isn't any leakage at all coming from the machine
Should I replace the part our just buy another Machine? That is the question.
I want to thank you all for giving me your time
Sincerely
John
Part isn't horrendously expensive, but only you really know how much work its done, how long you've had it, how happy you've been with it's performance etc - if you are looking for an excuse to replace it, could be a dealbreaker. More on the machine's half-life here: http://fixitnow.com/wp/2004/03/06/appliance-tip-of-the-day-how-long-should-appliances-last/
1 person likes this
We have had it for 8yrs. From that link you sent me it sounds like whirlpool is what to buy and RUN from GE products....
I thought Maytag Made the best washer and dryers...thats why I purchased it 8 years ago...decisions decisions.....
Have to talk to the wife about this one.
Hey Everybody!!
Again thank you for all your help.
I wanted to follow up with you guys on this problem I was having. I fixed the problem by replacing the Water Supply Faucets and it fixed the problem I was having.
You see the old cold water faucet would turn all the way up to full blast...so I got to thinking that maybe water pressure to the machine might make somethings go goofy. I don't know how the machine knows when and when not to go or when and when it full of water...I don't have a clue. Something just struck me that if the machine is only getting 1/3 of the cold water that it probably wants than there has to be some kind of Fuzzy Logic that the machine probably wouldn't run right.
So like I said change the water supply valves on the wall and after a couple of loads it readjusted itself and works like it brand new.
Who would have thunk
Thanks again for all you do
1 person likes this
Domo for posting what you found, John! I'm sure this will help someone else down the road.
Have you guys ever seen anything like this?
no and it really doesn't make sense to me, but if its working who am i to complain
1 person likes this
