Neptune Washer MAH9700AWW Motor Binding
#1
Posted 20 March 2012 - 12:06 PM
Motor seems to be binding. Check out videos of problem here.
http://neighboursapp...vate/jCvrggAmDA
Anyone seen this before? Ideas?
Servicing Southern Manitoba, Canada
#2
Posted 20 March 2012 - 05:58 PM
Did you measure the resistance of the stator assembly from the main board?
#3
Posted 20 March 2012 - 08:00 PM
Still stumped as to what is causing the drum to grab as if the motor was stopping it. BTW - there is no noise ... no grinding or anything like that when it happens - it just stops.
Edited by Strathy, 20 March 2012 - 10:49 PM.
#4
Posted 21 March 2012 - 08:58 AM
I'm not sure about the drum grabbing... hoping Master john63 will weigh in on this one and enlighten us.
There was a tech memo out on the E3 error that I posted about at my other site, not sure if you've seen it ==> http://fixitnow.com/...ah9700-washers/
Here's the link to the actual tech bulletin ==> http://www.mediafire.com/?eo2yznwaizn
#5
Posted 21 March 2012 - 10:34 AM
If a 3E and/or b2 error was displayed---and the HALL SENSOR / MOTOR / WIRES / PLUG CONNECTIONS are "good"...
Replace the MAIN BOARD.
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#6
Posted 23 March 2012 - 11:31 AM
EDIT: Hmmm ... when I look at the motor that is listed on Samauri page - that is a belt driven machine. The one I'm servicing is an integrated motor machine like this:
Tech Sheet does talk about the Hall sensor still though ...
I will still check the connections ... but will bring a motor with me. It looks like the Hall Sensor in part of the motor assembly on this style as well.
Edited by Strathy, 23 March 2012 - 12:04 PM.
#7
Posted 23 March 2012 - 10:49 PM
The remedy/solution turns out to be the MAIN BOARD.
Very frustrating---until you've developed an intuitive 6th sense when servicing older Samsung designs.
In most cases this can be verified by initiating the TEST MODE for the MAIN BOARD---if the 2nd or 3rd test sequence cannot be enabled/verified---replace the MAIN BOARD (see Tech Sheet for instructions).
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#8
Posted 24 March 2012 - 04:06 PM
Edited by sh2sh2, 24 March 2012 - 04:07 PM.
#9
Posted 24 March 2012 - 05:15 PM
#10
Posted 24 March 2012 - 07:26 PM
Every so often---the motor is energized to "run" in clockwise/counterclockwise at the same time (locked rotor).
If the plugs & wires are in good condition (no corrosion or chaffed)---and the HALL SENSOR and STATOR are within spec (ohms)---it *could* still be the MAIN BOARD at fault.
Trying not to "beat a dead horse" here---but these model washers drove me to the brink at times
It reminds me of LT. COL. Petrov.
He was a part of the soviet (nuke) missile command---monitoring/watching for *missile launch* signatures via satellite.
Petrov was not part of the missile detection station---but was *asked* to sit-in (assume command) for a fellow colleague for ONE NIGHT.
That very night---on his one-time shift---the alarm begins blaring and the entire missile warning screen lights up---announcing that a US missile launch was detected.
To make a long story short---Petrov *shut-down* the missile warning system (cancelled the alert) FIVE TIMES.
Turned out that sunlight at sundown on the US west coast---was reflected/refracted upwards---to the sensor(s) on the Russian satellite---producing a near-identical signature as that of a launched missile.
Petrov's hunch was correct---something was malfunctioning.
Working on the older Samsung washers---requires second guessing the machine's fault code logic
Edited by john63, 25 March 2012 - 12:51 AM.
- Samurai Appliance Repair Man, kdog and Strathy like this
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
