WHIRPOOL GAS DRYER is power reaching the coils (whirpool)
how to check if power is reac
5 replies to this topic
#1 mayolito
mayolito
  • 2 posts
  • Flavorite Brew:TKT
Posted 21 March 2012 - 10:23 AM
Please help any idea
I have a Whirpool Gas dryer, and gas valve not open.
Ignitor glows but turns off after gas vas valve not open, (it makes a click and ignitor turns off)
it looks to me that time of glowing is a little less than in other gas dryers
Dryer Motor runs ok
Thermal fuse ok
cut off sensor ok
thermal cut off ok
Ignitor ok 76 omhs
Flame sensor ok (continuity)
Coils replaced and ok (old & new ones)
Do you think that maight that box timer may have failure
How can I check if power is reaching coils
Thanks in advance!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 21 March 2012 - 10:37 AM
has this Dryer worked OK for you up till now at this location ?
OR has it been in storage ?
#3 jumptrout
jumptrout
  • 1,382 posts
  • Flavorite Brew:Coors Light
Posted 21 March 2012 - 05:26 PM
Does this dryer have a model number?
#4 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 21 March 2012 - 07:49 PM
Sounds like gas line has a shutoff behind dryer or in basement that is not turned on??? And do your hear a strange vibration when burner should be igniting and if so probally bad gasvalve! They say not serviceable but have tooken many apart and have fixed problem with no troubles! If it was in storage moisture probally bfound it's way in there and one of the plungers is stuck inside gasvalve!!!!
#5 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 21 March 2012 - 10:09 PM
Ten Commandments for Reading Appliance Model Numbers :)
Posted Image Posted Image
#6 mayolito
mayolito
  • 2 posts
Posted 23 March 2012 - 02:31 AM
Sōhei: thanks you are right !! This dryer was in an storage for some time, and also the line on basement it had a lot of lead paste. So first I discover the lead paste was obstructing the line but still not working so then I realize that the valve had a failure it opened a little like a pilot in the base of the burner.(moisture)
Solution I clean the gas line and Valve gas replaced.Now its working perfect. thanks again
