Whirlpool wall oven RBS245PDS17 stopped working aft. self clean
2 replies to this topic
#1 Gary225
Gary225
  • 1 posts
  • Flavorite Brew:Bud
Posted 21 March 2012 - 09:44 PM
The oven blacked out after the self clean cycle.
Replaced the thermal fuse that tested bad. No luck. I should have known from looking at the schematic because the panel should have still worked. Confirmed 120v power to the control panel plug. Found a short on the board @ location "C21" I think it use to be a capacitor before going to component heaven. So the board is bad. Are there any other components it would be smart to check before installing a new board ?
Thanks.
Gary
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 March 2012 - 06:14 AM
“My Rules”:
Rule #1) Don't ever use Self-Clean on any Oven.
Rule #2) If you're thinking about using Self-Clean, see rule #1.
Self-Clean uses nearly 1000F for 3 hours or more. Posted Image
That can wreak havoc on Electronic Controllers and Connections.
    Shōgun
  • Master Samurai Tech
  • 30,550 posts
Posted 22 March 2012 - 07:47 AM
Talked about the self-clean feature in that last issue of our Newsletter, Appliantology ==> http://fixitnow.com/...down-the-house/
Subscribe so you get your very own personal issue each time it comes out ==> http://newsletter.appliantology.org/
As for fixing your range, yes, you done blowed the circuit board, which is one of the more innocuous common hazards associated with using the self-clean feature, see the linked newsletter article for more.
Your part link ==> http://www.repaircli...ber=RBS245PDS17
