Asko 10505 washer repair manual
loungelizard
loungelizard
Hi there, think I need to replace the bearing on an Asko 10505 washing machine. Need the tech manual to see if I can do it(also will help me in the future if something else goes wrong) Doomo arigato in advance
  • Replies 7
  • loungelizard
  • danoam
  • Hank496
Added to the Downloads section just for you, budrow ==> :dazzler:
loungelizard
Bukka, that' s not really what I wanted. You wouldn't have a schematic diagram with parts listings? Thanks
Added to the download link above.
loungelizard
Thanks, changing the bearings wasn't as hard as I thought. Is it possible to change the bearings in the motor?
  • 1 year later...
Sorry to resurrect this old post. I downloaded manual and it seems kind of sparse. No schematic, or explanation on disassembly of components, just introductory explanations of major components. I can't see how OP got info to change bearings from this document. Is there anything with more detail?
Thanks
Hank
Schematic is part of the download bundle.  It's there, I added it myself.
  • 5 months later...
To my knowledge, there is no good instructions for replacing an Asko drum bearing. Be aware that if the inner drum needs to be replaced due to a loose spider or damage to the shaft, the part is no longer available. Also, performing this repair without the bearing installation tool and alignment tool for the drum, this job is a nightmare.
Sent from my SCH-I545 using Tapatalk
