FAQs | Store | Memberships | Repair Videos | Boot Camp | Newsletter | Beer Fund | Contact
Frigidaire Laundry Center FEX831FS4 No Agitate or Drain
9 replies to this topic
#1 vee8power
vee8power
    Kohai
  • 331 posts
  • Flavorite Brew:Folgers
Posted 23 March 2012 - 07:11 AM
This closet-dwelling washer will fill with water and stop; advancing the timer manually will start it spinning but no power to the drain pump. The lid will not lock so I changed the switch/lock, but that didn't solve anything. I traced wires around, particularly a black/red from the water valves to the lock to the timer. Somehow that leg of power is not making it to the pump, and it won't agitate. :yucky: I think I'm missing a simple solution here. Does anyone have any suggestions?
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 23 March 2012 - 09:08 AM
just to clarify ...
It will Fill
Then the Timer stops ?
It won't Agitate at all
It won't Drain
It will Spin if set to "Spin"
#3 vee8power
vee8power
    Kohai
  • 331 posts
Posted 23 March 2012 - 07:12 PM
Correct... And the lid doesn't lock when it spins.
    Shōgun
  • 28,709 posts
Posted 23 March 2012 - 07:41 PM
Do you have the wiring diagram for this unit that you can scan in and post? If it's easier, you can fax it to me toll-free at 866-315-4505.
#5 kdog
    RoughShod
  • 7,465 posts
Posted 23 March 2012 - 07:48 PM
Better Yet ,,,,,, (washer diagram page 12) : http://appliantology...-laundrycenter/
The Timers in those things switch neutral side, the Black/Red you mention is the hot feed in. It arrives through the motor overload.
    Shōgun
  • 28,709 posts
D'OH! How did I overlook to search our very own Downloads section!
Must be that spike in my head again. Posted Image
#7 vee8power
vee8power
    Kohai
  • 331 posts
Posted 24 March 2012 - 05:51 PM
Guess I have to purchase a subscription; can't download the washer diagram. I had servicetech... for a year. Seems like there was better information on here for free. :yes:
#8 kdog
    RoughShod
  • 7,465 posts
Posted 24 March 2012 - 05:54 PM
your machine will have it's own diagram placed nicely in an envelope stuck on the back of the front transition panel between the units
#9 jumptrout
jumptrout
  • 1,375 posts
  • Flavorite Brew:Coors Light
Posted 24 March 2012 - 06:39 PM
#10 vee8power
vee8power
    Kohai
  • 331 posts
Posted 27 March 2012 - 07:23 AM
I don't have a readable diagram. A new washer timer solved the issues :thumbsup:
