It's looks like the washer is giving a 1E error (is it an error code?)
I was able to start the washer once, started to fill then had manually shut valves off at the wall as it was going no stop filling. After I unplugged the unit the valves shut themselves off so the valve is not bad.
The dryer will not start on any heated cycles - it makes an attempt to start - like a thump thump - however the non heat cycle start the dryer just fine.
This unit looks old and has a pretty sophisticated wiring system....hoping there is help out there
Many thanks!
