LG Washer WM2101H Making Grinding Noise - Won't Spin
#1
Posted 23 March 2012 - 07:38 AM
Any chance that this is something we can fix ourselves? There is no error message. The machine seems to think it IS spinning. It's almost as if something came unattached inside. Naturally we did not do the smart thing and staple the receipt to the user manual, so I don't know if it will be covered under the warranty.
Thank you for any help you can provide!
#2
Posted 23 March 2012 - 08:56 AM
Check/inspect the 17mm bolt at the center of the ROTOR (this is part of the washer motor).
If loose---remove the bolt & pull off the ROTOR to inspect the *spline*.
If "stripped"---a new ROTOR will be needed.
http://www.repaircli...Number=WM2101HW
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#3
Posted 23 March 2012 - 07:34 PM
I see that we got this washer in June 2009 so we are just skating in under the three-year expiration, thankfully. I have used this washer for a minimum of one load of laundry EVERY DAY since we got it, usually more like three or four loads since we are an animal rescue family, so I can't really complain too much. It has been rode hard and put away wet many times - except that I always make sure the door is left open for at least four hours if there is not another load going right in. We have had no problems even though I see I have been using too much detergent and I was using Downey for our clothes (fortunately not for all the loads of towels for the animals) So I guess we have been lucky, up to now.
So glad there is a site like this to give us a clue when things go wrong. Thank you!
#4
Posted 23 March 2012 - 08:00 PM
#5
Posted 23 March 2012 - 10:17 PM
That's 3 times the normal workload (approx 1200 loads per year)
Every year the washer is put through 3 years worth of laundry.
This adds the possibility of a failed REAR BEARING/TUB ASSY.
With an extended warranty---all parts & labor should be 100% covered.
Some extended warranty companies will offer a full replacement washer if the repair cost is high.
Good luck
Musty odor
L-O-N-G cycle times
Suds error message
Slow spin speeds
Read below:
HE 3X: (1) Teaspoon
#6
Posted 24 March 2012 - 07:13 AM
should be using only HE detergent .. and sparingly...
IF you happen to have some non-HE detergent...
get it out of sight of the serviceman..
and replace it with HE detergent...
#7
Posted 29 March 2012 - 03:35 AM
Also tagged with one or more of these keywords: LG washer
