KainThornn
Yet another Maytag LAT8305AAE dead in the water
7 posts in this topic
Well...dead FULL of water...it's been bailed out and when I opened the control panel I found a lot of corrosion on the exposed metal. Anyways, it filled up just right, then stopped. No actions whatsoever. I found and repaired a few damaged wires and a bad terminal on the fuse, but still no motion. Neither the timer motor or the drive motor hum. Is this a bad timer or something I haven't found yet? Thanks!
Really? That's a whole lot better than the timer unit! Thanks!
Straaaange...I tried to check voltage at the switch..it started up...agitating...spin cycle...etc... :huh:
As Ahnold would say, "You'll be back."
Ahnuld iss goot for de Valkingk Dedt progrum on de telliffission...hiss careeah is dedt...undt he iss valkingk... :D
Doubt he has much to worry about - it's been a pretty good run for him
