Whirlpool ETW4400XQ washer Water temps
1 reply to this topic
#1 jrlead
jrlead
    Ikkō-ikki
  • 35 posts
  • Flavorite Brew:Bud Light
Posted 25 March 2012 - 10:23 AM
The owners manual states "Wash cycles with controlled temperatures are designed to maintain cleaning performance while using less water and energy compared to older traditional washers. As a result, water levels will be lower,
and hot and warm wash temperatures may not be as warm as you are used to"
So what temp should I expect when using the hot setting?
Jim
#2 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 25 March 2012 - 10:29 AM
I believe the tech sheet under the controls tells you exact temps! I want to say it's lke 65 to 75?
