Maytag. French door fridge.
3 replies to this topic
#1 lwb
lwb
  • 1 posts
Posted 25 March 2012 - 03:16 PM
The floor of the freezer gets water on it and freezes. i need to know where the plug is and how to remove it so i can unstop the drain. The warranty ran out a couple of month ago....my luck !!!!
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 25 March 2012 - 03:17 PM
Ten Commandments for Reading Appliance Model Numbers :)
Posted Image Posted Image
#3 kdog
    RoughShod
  • 7,474 posts
Posted 25 March 2012 - 03:20 PM
Remove the interior rear freezer cover and you will see the drain pan under the coils - drain hole is likely plugged/frozen and will need to be thawed out.
#4 Derik
Derik
    Sōhei
  • Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 25 March 2012 - 11:41 PM
And good idea to blow line out and take a piece of copper stranded wire and wrapping it around defrost heater and putting it in drain hole to avoid it from happening again!!!! Works like a charm!!!!!
