Need diagnosis help for Kenmore dehumidifier 580.54351
dehumidifier laundry small appliances
2 replies to this topic
#1 MKeating42
MKeating42
  • 19 posts
  • Flavorite Brew:OIe Leghumper
Posted 26 March 2012 - 08:42 PM
I have a 35 pint Kenmore dehumidifier, model 580.54351. It has not been used since last summer, when it was working fine. Now that spring has sprung, it would only run for a few minutes, then stop. For a few days, turning the humidity control knob to "off" and then "max" would convince it to run for a few minutes. Now it won't turn on at all. No fan, no compressor, no "bucket full" light (which also used to come on when the bucket was out of position).
I pulled it open and checked the fuse (fine) and capacitor (no obvious flashing or distortion). What's my next move to diagnose this thing?
#2 RegUS_PatOff
  • 30,264 posts
Posted 26 March 2012 - 09:37 PM
Sears Kenmore 580.54351 made by LG Goldstar
depending on the missing last (3) digits of the model number,
this may be a similar wiring diagram
#3 jumptrout
jumptrout
  • 1,136 posts
  • Flavorite Brew:Coors Light
Posted 27 March 2012 - 07:35 AM
Check for continuity in the rocker switch.
Check voltage through the rocker switch.
Check voltage to and from the transformer.
If no voltage problem replace the control board.
Also tagged with one or more of these keywords: dehumidifier, laundry, small appliances
