Kenmore washer will spin but not enough
#1
Posted 30 November 2005 - 07:28 AM
I have a Kenmore 110.12502100 washer. It will spin, but not enough to completely wring out the clothes. I followed the instructions for cadensdad "Kenmore washer won't spin", hoping it was the coupler, but the coupler on my machine looks good as new. Any other suggestions?
#2
Posted 30 November 2005 - 07:34 AM
#3
Posted 30 November 2005 - 08:08 AM
#4
Posted 30 November 2005 - 09:35 AM
#5
Posted 30 November 2005 - 09:44 AM
#6
Posted 30 November 2005 - 09:46 AM
When you checked the coupler, did you actually pull off the motor and check all three pieces of the coupler or did you just look at it from underneath. (hint: if your answer is the latter, then you need to do the former.)
#7
Posted 30 November 2005 - 10:03 AM
#8
Posted 30 November 2005 - 01:38 PM
Stick a pen or something into the hole where the lid switch plunger goes.(this is so you can run it in spin with the lid up, we are fooling the machine into thinking the lid is down.)
Turn the timer to spin on the normal or heavy duty cycle.(don't start it yet)
with one hand hold onto the top of the spin basket, and with the other start the cycle.
If you can easily prevent the basket from spinning, your clutch is worn out, or has some oil on it.
Nick
#9
Posted 30 November 2005 - 02:05 PM
Thanks.
