Whirlpool Duet GEW9200LW0 not working
GEW9200LW0
9 replies to this topic
#1 chikoo
chikoo
  • 4 posts
  • Flavorite Brew:Kingfisher
Posted 27 March 2012 - 08:00 PM
So after 8 years of working faithfully, my whirpool GEW9200LW0 dryer is not turning on.
The light inside the chamber comes on. That's it.
How do I perform the diagnostics on this model?
I tried the More Time -less time-more time-less time cycle to no avail.
Help!
#2 kdog
    RoughShod
  • 7,466 posts
Posted 27 March 2012 - 08:03 PM
Check and reset circuit breaker
If still no go, remove lower access panel and test the thermal fuse:
http://www.repaircli...mber=GEW9200LW0
#3 chikoo
chikoo
  • 4 posts
Posted 28 March 2012 - 03:51 AM
I reset the circuit breaker. Did not help.
The thermal fuse is the one shown on 4-7 here?
    Shōgun
  • Master Samurai Tech
  • 30,209 posts
Posted 28 March 2012 - 07:25 AM
The thermal fuse is the part that Grand Master kdog linked you to in the post immediately prior to yours. You know, the one with the purdy pitcher and the big bold words above it that say "click here"
#5 chikoo
chikoo
  • 4 posts
Posted 29 March 2012 - 09:02 PM
Thanks...what if the fuse is OK?
or is that thermal fuse the most likely culprit?
#6 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 29 March 2012 - 09:38 PM
could be
... bad connection on the Dryer Cord Terminal Strip
... broken Belt
... bad Door Switch
some electrical testing would need to be done ...
#7 kdog
    RoughShod
  • 7,466 posts
Posted 29 March 2012 - 10:28 PM
What if it isn't ?
#8 chikoo
chikoo
  • 4 posts
Posted 31 March 2012 - 01:07 PM
could be
... broken Belt
... bad Door Switch
So I finally got to the fuse and tested it as shown in the video. It shows continuity.
Now what?
By the way, the little pilot lamp in the drum turns on when I open the door so I figure the plug is ok.
What could be the next best bet and how to test for it?
#9 RegUS_PatOff
  • 33,588 posts
Posted 31 March 2012 - 01:41 PM
... What could be the next best bet and how to test for it?
... broken Belt
... bad Door Switch
#10 Derik
Derik
    Sōhei
  • Master Appliantologist
  • 239 posts
  • Flavorite Brew:coors light
Posted 31 March 2012 - 02:02 PM
Is your belt hooked to drum???you should be able to see it if you found thermal fuse!
