Amana Fridge top mount tx21r2e evap motor not getting power.
7 replies to this topic
#1 DurhamAppliance
    Sho' Nuff Chozin
  • 6,063 posts
Posted 27 March 2012 - 08:44 PM
Having problems on the neutral wire on The evap motor. This motor is wired to the defrost limit, but limit is good. The fridge will also intermittently turn off even though it has not reached proper temp. Cold control seems to be okay ..no sparking....shaking it does not cause it to turn off/on (have yet to bypass it to see what happens) compressor not running hot and the timer is very noisy. My gut feeling is that the timer is bad (remember having an Amana where a bad timer was causing interference with neutral line running to water dispenser). I guess my question is, can a bad timer cause evap fan motor not to get power and can it, even though not near defrost period, cause the compressor and condenser fan motor to stop working intermittently? Of course anything is possible, but wondering if anyone had similar experience. Thanks! btw this fridge has more screws than H Fleiss!
Edited by DurhamAppliance, 28 March 2012 - 01:35 PM.
www.DurhamApplianceThrift.com
#2 kdog
    RoughShod
  • Senior Appliantology Fellow
  • 7,474 posts
Posted 27 March 2012 - 10:53 PM
Did you happen to check the outlet polarity ?
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 28 March 2012 - 09:57 AM
I can't find any wiring diagram for that model,
unless you have one you could scan & upload somewhere ...
    Shōgun
  • Master Samurai Tech
  • 31,396 posts
Posted 29 March 2012 - 07:00 AM
I'm not finding anything on this one, either.
Absolutely, although I'm not saying with certainty that's what's happening here but it's within the operational purview of the defrost timer. Flakey wire harness connections are a common troublemaker. Check the terminal connectors in the molex connector on the defrost timer. Look for any darkening on the wire insulation leading up to those terminals. On at least one occasion, I've had to re-splice a whole new connector for the defrost timer because of one bad spade in the molex connector.
#5 asteysn2
asteysn2
    Asteysn2
  • Appliantologist
  • 212 posts
  • Flavorite Brew:Newcastle, Watneys, Stone's IPA
Posted 29 March 2012 - 10:39 PM
I had an Amana not long ago displayed very similar problem, I shorted the wires across the CC and it pulled down to -23 deg. Eventually I decided that the CC was flakey and I was right
Robert Sankey
Coastal Appliance, Heating & Air
Website: www.coastalappliances.com
email: coastalserve@gmail.com
#6 DurhamAppliance
    Sho' Nuff Chozin
  • 6,063 posts
Posted 31 March 2012 - 04:40 AM
There was no need to short cold control as the cold control bridged the hot wire. Evap fan problem was with the neutral line. There were actually two unrelated problems discovered after replacing timer. Timer fixed the intermittent shut downs but did not rectify fan problem. There was a short somewhere. I tested seemingly hundreds of wires from timer, lights, switches, molex connectors to nuclear reactor rods... Nothing. So I rerouted a neutral from the unused ice maker wires, crimped a connector on it and attached it to the fan motor. Tested fan reactions in defrost, and different temp settings while taking amp readings (needed to make sure nothing else was running inadvertently due to rerouting ). Two days and all is well.
Edited by DurhamAppliance, 31 March 2012 - 03:48 PM.
    Shōgun
  • 31,396 posts
Posted 31 March 2012 - 08:37 AM
Nice shootin', Durham! :armed:
And domo for posting what you found!
#8 DurhamAppliance
    Sho' Nuff Chozin
  • 6,063 posts
Posted 31 March 2012 - 03:44 PM
Thanks....sorry I've been making a lot of typos lately, been using my Samsung Pad and typing on a touch screen ...nothing beats a full old fashioned keyboard!
