LG LMX25981ST refrigerator -- man'l req and disp. problems.
12 replies to this topic
#1 DanInKansas
DanInKansas
    Senpai
  • PipPipPipPip
  • 505 posts
  • Flavorite Brew:Lion Imperial or Shiner Bock
Posted 27 March 2012 - 09:08 PM
I am seeing some weirdness on this line of LG refrigerators on the dispenser. I have two in queue where I am doing to need to replace the water switch (sticks closed and pours water on the floor) and work on the ice door flap (sticks open and lets warm air in.)
1) Anyone have a manual for this? LG LMX25981ST/01 or 03.
2) Anyone know how to get at this dispenser? Both the ones I have waiting for me have stainless steel finishes and the dispenser housing is flush with the front door! Doesn't look like you get at it from inside the left door, which means.... I take the putty knife and try to pop out the frame? That's what I would do with the fridges where the frame sticks out from the door -- but looking at this, I'm not even sure where to start the putty knife. A little apprehensive; looks like infinite opportunity to scratch up finishes!
What is the simplest, dumbest explanation? Because that's the most probable one.
#2 DanInKansas
DanInKansas
    Senpai
  • PipPipPipPip
  • 505 posts
Posted 31 March 2012 - 10:19 AM
Bumping. Anyone with ideas on how to dismount that flush-with-the-door dispenser? None of the techs I work with have had to do this yet.
    Shōgun
  • Master Samurai Tech
  • 30,213 posts
Posted 01 April 2012 - 06:17 PM
Working on it, hang tight...
    Shōgun
  • 30,213 posts
Posted 01 April 2012 - 06:39 PM
Service manual added to the Downloads section ==> http://appliantology...21981-lmx25981/
#5 DanInKansas
DanInKansas
    Senpai
  • PipPipPipPip
  • 505 posts
Posted 02 April 2012 - 07:51 PM
Awesome.... so if I'm reading the manual correctly, you essentially get to the dispenser by using your hands and wiggling stuff.
    Shōgun
  • 30,213 posts
Posted 02 April 2012 - 09:08 PM
LOL! I wish I had more specific info for you on disassembling the dispenser but I've never done it on this model. I was hoping Master John would stop by and offer some pointers on this. I'll look around some more and see what I can find.
    Shōgun
  • 30,213 posts
Posted 02 April 2012 - 09:15 PM
On *most* of these LG refrigerators, the dispenser frame just pulls out. Here's some disassembly help for a different LG model. Procedure looks like it may be the same or similar for yours ==> http://fixitnow.com/...s-refrigerator/
    Shōgun
  • 30,213 posts
Posted 02 April 2012 - 09:19 PM
From page 9 of the manual that I posted for you:
2) Hold the inner side
of cover dispenser
with both hands at the
handle side to pull it
out forward.
#9 john63
john63
    Dean of LG Appliantology
  • 2,212 posts
Posted 02 April 2012 - 09:29 PM
Per LG training...
Explain to the customer that---removing the DISPENSER ASSY *will* sound as if you (the servicer) are rough/unprofessional.
When removing the entire Housing---loud snapping sounds are produced.
This is normal.
1) Slide forward and remove the Dispenser drain tray (place finger(s) at the back/rear and squeeze locking tab)
2) Grasp the bottom of the DISPENSER HOUSING and firmly pull towards you (plastic straining noise will occur)
3) Working from the bottom---move to the lower edges and continue pulling/unsnapping the Housing Assy.
4) Since the DISPLAY is situated on the left side of the Housing---all wire connectors are on the left side.
5) Re-installing is much easier than removing. Apply effort to be certain that the Housing is fully snapped in place.
NOTE: Again---per LG---it is NOT uncommon for one or two plastic *tabs* to break when removing the Housing.
This was designed to still adequately be installed---minus a locking/snap tab or two.
Explaining this to your customer will eliminate their concerns---and you'll be thought of as a professional because you
took the time to explain all of this to your customer *before* starting your repair work.
Not much different than having a doctor that tells a patient bluntly:
"Yes, this needle *will* hurt,but the medicine that I'm injecting is the cure for what ails you".
Edited by john63, 06 April 2012 - 06:10 PM.
To eliminate:
Musty odor
L-O-N-G cycle times
Dingy/yellowing whites
Suds error message
Slow spin speeds
Read below:
HE 2X: (1) Tablespoon
HE 3X: (1) Teaspoon
#10 kdog
    RoughShod
  • 7,466 posts
Page 9 of the manual located here: http://appliantology...21981-lmx25981/
    Shōgun
  • 30,213 posts
Posted 02 April 2012 - 09:30 PM
Per LG training...
I'd like it twice if I could! Domo, John! :)
#12 DanInKansas
DanInKansas
    Senpai
  • PipPipPipPip
  • 505 posts
Posted 02 April 2012 - 09:33 PM
Yeah, I was reading that and looking at the photo. It seems a little hard to visualize, but I'm sure I will get it when I'm at the house. I'm definitely going to print John's bullet points and take them into the house with me.
#13 DanInKansas
DanInKansas
    Senpai
  • PipPipPipPip
  • 505 posts
Posted 05 April 2012 - 09:32 PM
Per LG training...
John63 wins! This method worked extremely well. The only note I would make for anyone's future reference is that I wasn't getting anywhere using my bare fingers. When I put on my rubber gloves, the dispenser came right out.
