Sign in to follow this
Followers 0
barkster
How to Test Control Panel on Jenn-air W256B #Y04100040
10 posts in this topic
looks like our touchpad for our W256B double oven when out, whit the touchpad plugged in it beeps like crazy and display is constantly changing. I've put an ohm meter across ribbon cable and don't see any continuity on any of the buttons. How do I test this touchpad. I'd buy a new one if anyone still had them but looks like they quit making them in 2009. Thanks
Here is the part in question http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/Y04100040/1242474
this similar key-matrix may be yours
Thanks for the reply, mine has 12 pads. So essentially I should be able to put ohm meter across 10 and 3 and press upper bake and should show continuity correct?
Up to 1000 ohms I believe!
correct, but I don't think that diagram will work for your model ..
I can't seem to find one any other one .. yet
yeah I've put ohm meter across one pad then pushed button and then touched to each other pad and didn't get anything. I don't think my touchpad is out completely cause some buttons work I just think one is stuck because it is always trying to set timer.
just a reminder,
need to set OHM meter high than 200 OHMs
thanks, I'll check again
... you'd then have to "put ohm meter across the" second pad then push button and then touch all remaining pads, etc, etc, etc
yeah I tried that and didn't get a reading from any of the buttons which seemed odd because some of them still work. I tried 200ohm and higher with no luck. No biggie, thanks for the help
Followers 0
