Honeywell Chronotherm III, T8600D1111, furnace/AC, clicking twice, won't turn off
sbdivemaster
sbdivemaster
Hi, I have an old Honeywell Chronotherm III, T8600D1111. This morning, while the heat was on, the tstat would reach temperature, then click twice real fast, and the air keeps blowing. I tried lowering the heat set point, but it still clicks twice and keeps running. I'm pretty sure the tstat is shot, and I think a replacement is in order. I have found a few places that say to go to the Honeywell VisonPRO 8000, but I don't know which model is the direct replacement.
Would the Honeywell TH8110U1003 be the correct one?
Any help is much appreciated.
Edited by sbdivemaster
  • Replies 8
  • sbdivemaster
  • jumptrout
  • kdog
sbdivemaster
For a upgrade programmable stat,that one is fine.
Arigato, Jumptrout Senpai.
Would any of the other Honeywell tstats also work? E.g. TH6110D1005 FocusPRO, TH4110D1007 PRO 5-2, or any of the others listed here:
http://www.honeywell...ogrammable.html
We don't need anything really fancy, but I do like the ability to set different temperatures for different parts of the day - Wake up, away, home, sleep, etc. We don't live in an area where we would need heating and cooling on the same day, but I do like the adaptive recovery feature. I just don't know much about all the bells and whistles found on various thermostats...
They will all work.
My personal preference has nothing to do with programmable.
Too old fashioned.
I will adjust it myself.
Gives me something to do in my off time.
Edited by jumptrout
Agreed - what could be better than - look if I just turn this dial to a temperature thats comfortable, the furnace will come on as needed to keep the area warm enough - what more could I want !
sbdivemaster
Thank you again, Jumptrout Senpai. And thank you, Kdog Poop Daddy. I like the programmable for the summer time, so when we are not at home the AC will run at a higher temp, but cool down before we get home. When it's 100°+ (much of the summer), it really does help keep the electric bill down.
sbdivemaster
OK Got the Honeywell Pro4000 tstat - blower still going. :mad:
So, I fugured out that there is a LED blinking a code...
Starting new thread.
You can continue here.
What code?
Sounds like a stuck fan relay to me.
sbdivemaster
I thought it better to start a new thread, as it was a different problem than what I started this thread for.
I did manage to fix the problem, and the new thread is here:
